power injectors
curtw
Community Member
I would like to find the part numbers for power injectors approved for use with the WAP321, WAP 551, and WAP561  for North America
Charles Hill
Hello curtw,
The following links point to the data sheets which will give you part numbers for the needed power supply.  It seems all 3 access points use the SB-PWR-12V-NA, but please reference the links to confirm.
 SB-PWR-12V-NA
Cisco Small Business 12V Power Adapter (North America)
http://www.cisco.com/c/en/us/products/collateral/wireless/wap321-wireless-n-selectable-band-access-point-single-point-setup/c78-697406_data_sheet.html
http://www.cisco.com/c/en/us/products/wireless/wap551-wireless-n-single-radio-selectable-band-access-point/index.html
http://www.cisco.com/c/en/us/products/wireless/wap561-wireless-n-dual-radio-selectable-band-access-point/index.html
Hope this helps,
if so, please rate.
Charles Hill
Hello curtw,
 SB-PWR-12V-NA
Hope this helps,
if so, please rate.
Leo Laohoo
Let me tell you a little secret:  Cisco does NOT make power injectors.  They source the "Cisco-branded" power injectors from one manufacturer.  You can find 15.4w PoE power injectors HERE or you can also find 30.0w PoE+ power injectors HERE.
muhasidd
Visitor
Hello Curtis ,
You can go through the following link
www.cisco.com/cisco/web/solutions/small_business/products/wireless/
