Power Saving Mode for Access Points?
fhk-cwempe
Level 3
Level 3
I was wondering if there are any features to help saving energy with Cisco access points.
I know there are Power Saving Modes for VoIP phones.
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-6900-series/solution_overview_c22-589129.html
Is there something similar for access points?
It would be great if the access points could be put in a power saving mode at night, where wifi still works, but offers less bandwidth for example.
good question. i found some feature related to this. check this link.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-8/config-guide/b_wl_17_8_cg/m_access_point_power_control.pdf
Good luck
KB
7 Replies 7
balaji.bandi
i do not believe that is possible i guess.
BB
Good luck
KB
I think this is exactly what I was looking for.
Thanks!
Unfortunately, I think it will take a while until we can and will upgrade to IOS XE 17.8 on our controllers.
Still need support for older APs.
But that is another issue. 🙂
We have split out deployment in 2 WLCs one to host IOS-APs and running 17.3 train, and other for COS-APs progressing through new major releases.
Leo Laohoo
Not sure how anyone could save from 30.0wac power utilization when the PoE is on at all times.
@leo , I had the same doubt 🙂 how can this help businesses aiming to 'Go Green'? 😛
as the PoE switch or power injector will already be consuming what is needed for the AP. Or am I missing something?
Cisco power supplies are on "full throttle" at all times.  They do not drop consumption when utilization is low.
