Bookmark
Subscribe
10330
RED light is flashing continuously on Access Point AIR-AP2800, does not join WLC
Access Point AIR-AP2800 does not join WLC. I see a RED light is flashing continuously. Tried reconnecting but the same issue. Can someone advise on this, please?
Patil
balaji.bandi
check below thread  for red color what is the status :
https://community.cisco.com/t5/wireless/flashing-and-moving-red-light-in-ap/td-p/2758783
if you want to investigate, console and check.
BB
Many Thanks Balaji. I will go through the details.
Leo Laohoo
If the LED is flashing RED then it means the AP is most likely to be stuck in u-boot.
Many Thanks Leo. I will check it further.
