Replace 5520 standby unit
tiwang
Level 7
Level 7
hi out there
I have a 5520 WLC running 8.10.something with SSO enabled. I have to replace the standby-unit - is there a way to awoid interrupting operations? As far as I can see the suggested way is to disable SSO - which will cause both devices to reboot -> our global wlc will be down for a pretty long periode...
Is not not possibly to load the current config of the standby device on the new stnadby unit - fysically switch the device of and replace?
Rich R
I don't think any interruption is needed.  Turn off secondary.  Install and configure new secondary exactly as old one, same firmware and software as old one.  When you enable SSO it should reboot and sync to primary.
https://www.cisco.com/c/en/us/support/docs/interfaces-modules/wireless-services-module-2-wism2/117729-configure-wlan-00.html#anc7
"Replace the Primary WLC in HA Setup
The primary WLC was affected and the user must replace it. The secondary WLC is up and all APs are attached to it. The new WLC received return material authorization (RMA) can be added with one of the failed WLCs in the HA pair. Follow the steps in this section in order to understand how to replace a WLC in active setup.
  1. Make sure that the first WLC is the same version as the other WLC.
  2. Configure the WLC with the same subnet management IP addresses as the previous WLC.
  3. Configure the new WLC with HA configuration that includes redundant management, IP address, and peer primary. Enable the AP SSO.
  4. When the AP SSO is enabled, it reboots. While it reboots, the AP SSO discovers the current active secondary, syncs the configuration, and transitions to a hot standby state.
Note: You do not need to break the HA configuration on the current active WLC or reboot the current active WLC. The configuration will be synced with the current active WLC."
Same as that but secondary.
https://community.cisco.com/t5/wireless/replacing-8510-wlc-in-an-ha-pair-environment/td-p/3076933
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
balaji.bandi
You do not need to config all the information for the failed unit - check below thead to replace RMA unit.
https://community.cisco.com/t5/wireless/wlc-5508-replace-primary-unit-in-ha-pair/m-p/3094412
BB
Yes i have seen that but my goal is to avoid interruption of the traffic. This will force a reboot of both wlc's as i read it - i need a way to avoid interruptions
Rich R
