Bookmark
Subscribe
2999
Setting maximum concurrent login on 9800 WLC GUI
askingforuser
Hi, does anyone know where can I find the place that we can set the number of maximum concurrent login on 9800 WLC GUI? I was referring to the CISCO best practice and it teaches us how to set through CLI but I want to set at the GUI instead, does anyone know which tab or area should I go to in the GUI? thank you!
7 Replies 7
marce1000
  - To be honest , if you can set that parameter through CLI , then that is preferred ; sometimes  a particular parameter lacks implementation in the GUI ; let alone that this question when needing the GUI for it may lead to a race condition...
          You may also want to share how you do it in the CLI , this could help us find it in the GUI too ,
 M.
in the security guideline it said:
User login policy
Configure user login policies by entering this command:
C9800(config)# wireless client max-user-login ?
<0-8> Maximum number of login sessions for a single user, 0-8 (0=Unlimited)
Verify the user login policies by entering this command:
C9800# show run | I max-user-login
  - Ref : https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-743627.html#Userloginpolicy
      The max-user-login parameter does not refer to WLC GUI  administrative users , but wireless end user policies (restricting logins from different devices with the same credentials)
 M.
Sandeep Choudhary
At the moment, I dont think its possible to configure this using GUI on 9800 series WLCs.
Dont forget to rate helpful posts
askingforuser
actually I may find something similar on GUI: Configuration > Wireless > Wireless Global > Maximum Login Session Per User
Gaurav  Kansal
Dear User,
Please try this option which you find on below location:
Administration > Management >  *HTTP/HTTPS/Netconf/VTY > Timeout policy configuration > maximum number of request (* Please set this according to your need)
GoodLuck
Gaurav Kansal
If you find this post helpful then please vote as Helpful and if it solves your issue then please mark as Solution.
