vWLC Installation on physical machine
c1szhibin
I was planning to install a virtual wireless LAN controller on a physical machine.
But I failed to install when i enter the “bash” mode look like a linux user-interface.
I wanna know if vwlc has to be installed based on vmware environment?
even if I use iso file instead of ova?
File name: AIR-CTVM-k9-8-1-102-0.iso
2 Accepted Solutions
Q: I wanna know if vwlc has to be installed based on vmware environment?
A. Yes it installed  based on vmware environment
For deployment and management of the vWLC, you will need to download any of these VMware suites to the workstation:
  • Single ESXi server management - Use VMware vSphere Client.
  • Multiple ESXi servers requires vCenter - Advance features are also tied with vCenter which needs separate licenses (vMotion, and so on).
 Please go through  the below complete configuration guide of vWLC.
http://www.cisco.com/c/en/us/support/docs/wireless/virtual-wireless-controller/113677-virtual-wlan-dg-00.html
mohanak
AIR-CTVM-k9-8-1-102-0.iso  : Cisco Wireless LAN Virtual Controller Installation with 60 day evaluation license (KVM).
Cisco Virtual Wireless Controllers on the Cisco Services-Ready Engine (Cisco SRE) or the Cisco Wireless LAN Controller Module for Cisco Integrated Services Routers G2 (UCS-E)
Kernel-based virtual machine (KVM) is supported in Cisco Wireless Release 8.1.102.0 and later releases.
Note After KVM is deployed, we recommend that you do not downgrade to a Cisco Wireless release that is older than Release 8.1.102.0.
Hello
friend
im installing on vmware the AIR-CTVM-K9-8-1-102-0, but what is the username and password in the initial configuration??
Best Regards!!
mohanak
