Web Gui problem
amel.idrizovic
Community Member
I have problem with my air ap 1702i converted to w7 ios.all is ok but when i login on web gui and try save or apply anything i get error 404 not found
Any tip
Tnx
49 Replies 49
sddweb
Visitor
Having the same issue with some 3602i's that I converted to standalone also w/153-3.JF11.   Can access all settings pages through the GUI, but when you change anything apply and click "OK" in the pop-up warning box, it displays "404 not found" in the text frame.
I would check using CLI whether those config changes are there on your AP? You can find any un-saved configs using below CLI command. In that way you know configs will be there, if not saved you can save it in CLI (write mem).
AAP1#sh archive config differences nvram:startup-config system:running-config
Also I would try with different image (eg ap3g2-k9w7-xx.153-3.JC)
Rasika
Same problem here with a 2702i using the following software:
ap3g2-k9w7-tar.153-3.JK.tar
You can save config changes in the CLI and it will show on the WebGUI but if you try to change anything and apply via WebGUI it faults with 404 error page not found.  Any solutions?  I tried all browsers and even different machines same problem.  I went as far as I formatted the AP and redownloaded software to make sure not corruption issue.  This is very odd.  Maybe revert to a previous version or this version has missing files.  Any help would be appreciated or suggestions?
-Fred
I would try a different image instead of tinkering around to try to fix this. If another image works, you pretty much found your answer. Faster to try a different image, you can always play around with the image later after you get it working.
-Scott
I don't believe it is the software as the three other people on this thread and using completely different versions, so that would not make sense that it is the software.  Has anyone had luck figuring out what the issue might be?  Browser?  Does the gui rely on specific HTML or standard to operate correctly?  just throwing ideas out there.  Thanks.
-Fred
its confirm 100% software version issue, if you still have issue I can help with remote.
try this video,
https://youtu.be/iY3TybqOSRg
You should see how many folks here have upgraded and or downgraded to an image one higher or lower and had the same issue until they downgraded a few trains or minor releases.  HTTP on standalone ap's was not the greatest and that is why many whom been around standalone would only use the cli.
-Scott
Downgrading to earlier firmware doesn't solve the issue.  Appears to be the 1-1-2020 credentials expiration bug.
https://www.cisco.com/c/en/us/support/docs/security-vpn/public-key-infrastructure-pki/215118-ios-self-signed-certificate-expiration-o.html#anc2
I have the same Problem.
404 Not Found
 Where ever in web UI you click Apply  you get
WARNING:
The settings shown on this page will be updated.
Click 'OK' to continue.
And then 404 Not Found. On all browsers. On all units. Many people across the globe have it.
Reproducible 100%.
You have released software to the public without even a simple smoke test? - what does it tell about your Quality! ?
Is it fixed?
Spent some time trying to pin this down; tried a few things - formatted flash with clean IOS install (verified SHA to rule out corruption), tried older version... all with same error.  Then I found a thread discussing this same 404 error/issue in regards to the "January 1, 2020 SSC" error:
https://www.cisco.com/c/en/us/support/docs/field-notices/704/fn70489.html
Now trying to find a workaround that actually WORKS to see if this solves it.  If anyone can come up with a step by step quick fix for this, that would be swell!
do you have a solution yet? i have the same error on my 1702i
Cisco just release for WLC 8.5.161.0 with a fix for the certificate bug. So I guess you will very soon (if not already) have a new image for the AP available to download.
