Web Gui problem
amel.idrizovic
Community Member
I have problem with my air ap 1702i converted to w7 ios.all is ok but when i login on web gui and try save or apply anything i get error 404 not found
Any tip
Tnx
49 Replies 49
I have a May 2020 release on my 3502e, all the certificates are OK but I got the same problem.
As I mentioned used the previous one no the latest one.
Umair Awan
Frequent Visitor
Frequent Visitor
I dont know your issue solved or not
in short, issue was with the firmware version.
try this video,
https://youtu.be/iY3TybqOSRg
mfarrington01
Community Member
Just an FYI for anybody searching around for a solution to the "404 error" problem and comes across this thread but is still confused, here's what I did to fix this problem!
For reference, here's what I was troubleshooting and where I'm at now:
Cisco IOS Software, C2700 Software (AP3G2-K9W7-M), Version 15.3(3)JJ1, RELEASE SOFTWARE (fc3)
I tried using different iOS versions as previously mentioned but this never fixed the actual issue where EVERYTHING i did resulted in a 404 error. I could reach the web portal no problem, but everything after that point was the issue...Quick setup? Nope, 404 error. Update some setting? Nope, 404 error, etc.
I tried, ap3g2-k9w7-tar.153-3.JI5.tar, JI6.tar, JPJ3a.tar, and JJ1.tar. JPJ3a.tar seemed to make the problem worse...things didn't seem right and MORE information was missing...but that could've been just me. I ended up settling with JJ1.tar as my final firmware (currently using)
So, what I think ultimately fixed the issue was this - https://www.cisco.com/c/en/us/support/docs/security-vpn/public-key-infrastructure-pki/215118-ios-self-signed-certificate-expiration-o.html#anc2
Reading through this was a HUGE help! (This was already posted earlier in the thread by another user, so not trying to steal thunder 😛 just...it was SO helpful!) Specifically section "Workaround 2 - Use the IOS CA Server to generate a new certificate"
I wanted to cover all my bases, so i zero'd my RSA keys and started with scratch.
I had to configure SNTP on the AP (used 0.us.pool.ntp.org) and synced up date/time then went through and followed the instructions in Workaround 2. I then generated my RSA general-keys and then configured SSH 2.0 and http secure-server...after doing all that, I was FINALLY able to log into the web portal and use the Easy Setup without running into the 404 error after every change!
I hope this helps somebody, because I've been banging my head against the wall trying to figure this out before stumbling across this thread! 😄
Thanks for posting your fix. It should help others whom might run into the same issue later on.
-Scott
After experiencing the '404 not found' issue on my Aironet 2701i, I downgraded it to the following version:
Cisco IOS Software, C2700 Software (AP3G2-K9W7-M), Version 15.3(3)JI4, RELEASE SOFTWARE (fc1)
I was then able to successfully apply changes via the web GUI.
I'm just wondering why the Cisco AirProvision mobile app disappeared (maybe replaced by a newer app?) - I couldn't find neither on the Apple Store nor on Google Play; in order to prime my AP I had to manually install the apk.
Would really appreciate if you help with the step by step guide? As i have tried and clean install and followed the Workaround but ist all in-vain.
try this
Hello @mfarrington01
could you please be so kind and describe your workaround step by step?
Kind Regards Robert
mmiersebach
Frequent Visitor
Frequent Visitor
Hi I am using a
AIR-CAP3602I-E-K9
with the Software Version: ap3g2-k9w7-xx.153-3.JF10 (ap3g2-k9w7-tar.153-3.JF10.tar)
The Web GUI Works and I can do changes:
I tried:
ap3g2-k9w7-tar.153-3.JF11.tar
ap3g2-k9w7-tar.153-3.JF12.tar
These releases definitely have this BUG and have no working Web GUI which means you can't Apply any Changes.
Thanks for posting your solution.
I hope this will also help others.
Thanks!
Tried ap3g2-k9w7-tar.153-3.JF12.tar and ap3g2-k9w7-tar.153-3.JF15.tar both same 404 error
ap3g2-k9w7-tar.153-3.JF10.tar works!
patoberli
There's a new update out, that's supposed to fix this issue:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvu61065
m.rana.ku
Level 3
Level 3
In the following video step by step process has been shown How to Configure Cisco AIRONET 3602i Autonomous/Standalone Access Point using GUI with WPAv2 Authentication Key.
https://www.youtube.com/channel/UCmZZ2BNGXQH1HPS3uIVnr7A?sub_confirmation=1
https://youtu.be/AwuWsGGofT4
Configuring Aironet Access Point with WPAv2 Authentication in GUI :
1. In Easy Setup
Under Network Configuration
Edit AP hostname, Static IP, Subnet mask and Default Gateway
Under In Radio Configuration
Create SSID name WLAN_New under Radio 2.4GHz and select Broadcast SSID in Beacon
2. Apply Encryption Modes to AES CCMP
3. Enable WPAv2 and apply WPA Pre-shared Key: to SSID
4. Enable Wireless Radio Interface (Radio0-802.11N2.4GHz/ Radio1-802.11N5GHz) UP
5. Save the configuration
Configure_Cisco_AP #Standalone_GUI #IT_Support_People IT Support People Facebook Page: https://www.facebook.com/IT_Support-PeopleDesktop-Support-111268543923018 Link for Other Related Videos: Configuring Cisco Router to Access Internet through ISP Home router: ...
