WLAN Cisco 5520 Wireless Controller
abc1235
Level 4
Level 4
Hallo,
We have vlan 300 (WLAN - Cisco 5520 Wireless Controller) configured in verious routers and the clients get IP addresses from a central DHCP server. The configurations are the same and all locations are working well apart from one. When I check the WLC, the APs are up but the DHCP server does not lease any addresses which means that there is no WLAN. Could anyone know what he issue is?
Thanks.
You are not really extensive with information to your environment. But as a guess as that could easily go wrong:
Do you run your APs in FlexConnect with local switching? Then it could be that VLAN 300 is just missing on the problematic location.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
10 Replies 10
Arshad Safrulla
You need to provide more information on your setup to provide you with a solution. Such as
AireOS code running?
AP models?
Flex or Local mode AP's?
If Flex local or central switching?
Do you have the WLAN configured in your WLC?
Is the AP's assigned to correct AP group and Flex group?
If local mode DHCP bridge mode or proxy mode?
Scott Fella
I agree that you need to provide more information.  From what I got from your post, you have this same setup in other locations and this location is the only one that isn't working right.  To me, you need to put a wired laptop on vlan 300 and see if it gets a dhcp and the correct dhcp address.  This will help eliminate if the issue is with your infrastructure configuration or maybe your wireless configuration.
-Scott
Leo Laohoo
Is the AP getting a valid IP address or not?
abc1235
Level 4
Level 4
Hallo all. Thanks for the feedback and sorry for the scanty info.
@Karsten Iwen yes, the APs are running on Flexconnect mode and VLAN300 is configured in the WLC. I restarted the 4 APs and now I see that one client is allocated an IP address of 0.0.0.0 but after a while doesn't show anymore (A pop up appears saying: No client can be found any more by this MAC Address).
@Arshad Safrulla Here is additional info.
AireOS code running? - 8.10.151.0
AP models - AIR-AP1832I-E-K9
Flex or Local mode AP's - Fleconnect mode
If Flex local or central switching?- Flex local switching
Do you have the WLAN configured in your WLC? - Yes, it is
Is the AP's assigned to correct AP group and Flex group? - Yes, I have confirmed that the 4 APs are in the correct froups
If local mode DHCP bridge mode or proxy mode? - DHCP Proxy mode is set to global which I understand is 'Global'.
@Scott FellaThat was what we initially tried but the WLAN was not even recognizable in the problematic location.
@Leo Laohoo From the WLC, the 4 APs are all getting IP addresses.
Are the wireless clients getting IP addresses?
abc1235
Level 4
Level 4
@Leo Laohoo No client is getting IP address. Initially one client got a 0.0.0.0 address then after a while a pop up appeared saying No client can be found any more by this MAC Address
On the SSID, is "IP address required" ticked?
abc1235
Level 4
Level 4
Yes it is.
abc1235
Level 4
Level 4
Hallo all. The problem has been solved. The issue was that the VLAN was not configured in the backbone router. This has been done and now everything is working properly. Thanks al for your input.
