WLAN Controller - reg
ctioko
Community Member
Hi, I have been working with WLAN controller 4402 for a while now however some strange thing happened this morning. all registered LWAP APs disappeared. upon rebooting, all of the APs came back (registered) but started disapperaring one by one after a few seconds. anyone knows whts happening?
7 Replies 7
dennischolmes
Level 11
Level 11
Check the WLC date and time. It sounds like the certificates are out of synch. THe AP's have a certificate on them that allows for the encrypted LWAPP tunnel to be established between them and the controller. If the time on the controller is wrong then the APs will not join permanantly. The APs also will reboot several times if there has been a code update done on the WLC. This occurs as the APs look for the version of code they are running as compared to the one on the controller. If different, then the APs will download the version of code on the WLC, later version or earlier.
Hi, I checked the time on the controller and adjusted it accordingly but the same thing keeps happening. the debugs show the controller receiving LWAPP Discovery Requests and responding succefully yet nothing else happens.
below is some logs
P Disassociated. Base Radio MAC:00:1b:2a:12:71:50
2 Tue Jun 10 08:11:16 2008 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:1b:2a:12:71:50 Cause=Max Retrasmission
3 Tue Jun 10 08:11:16 2008 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:1b:2a:12:71:50 Cause=Max Retrasmission
4 Tue Jun 10 08:11:04 2008 AP with Base Radio MAC 00:1b:2a:12:71:50 (NSSF-BLKA08thfloor-AP08B) is unable to associate. The regulatory domain configured on it '-E' does not match the controller's country code: Argentina
5 Tue Jun 10 08:11:02 2008 AP Associated. Base Radio MAC: 00:1b:2a:12:71:50
6 Tue Jun 10 08:10:59 2008 AP Disassociated. Base Radio MAC:00:1b:2a:12:71:f0
7 Tue Jun 10 08:10:59 2008 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:1b:2a:12:71:f0 Cause=Max Retrasmission
8 Tue Jun 10 08:10:59 2008 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:1b:2a:12:71:f0 Cause=Max Retrasmission
9 Tue Jun 10 08:10:58 2008 AP Disassociated. Base Radio MAC:00:1b:2a:12:70:a0
10 Tue Jun 10 08:10:58 2008 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:1b:2a:12:70:a0 Cause=Max Retrasmission
11 Tue Jun 10 08:10:58 2008 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:1b:2a:12:70:a0 Cause=Max Retrasmission
12 Tue Jun 10 08:10:58 2008 AP Disassociated. Base Radio MAC:00:1e:7a:3a:a9:90
13 Tue Jun 10 08:10:58 2008 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:1e:7a:3a:a9:90 Cause=Max Retrasmission
14 Tue Jun 10 08:10:58 2008 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:1e:7a:3a:a9:90 Cause=Max Retrasmission
15 Tue Jun 10 08:10:56 2008 AP Disassociated. Base Radio MAC:00:1b:2a:12:71:20
16 Tue Jun 10 08:10:56 2008 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:1b:2a:12:71:20 Cause=Max Retrasmission
17 Tue Jun 10 08:10:56 2008 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:1b:2a:12:71:20 Cause=Max Retrasmission
18 Tue Jun 10 08:10:56 2008 AP Disassociated. Base Radio MAC:00:1b:2a:12:72:50
19 Tue Jun 10 08:10:56 2008 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:1b:2a:12:72:50 Cause=Max Retrasmission
20 Tue Jun 10 08:10:56 2008 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:1b:2a:12:72:50 Cause=Max Retrasmission
21 Tue Jun 10 08:10:53 2008 AP Disassociated. Base Radio MAC:00:1b:2a:12:70:20
22 Tue Jun 10 08:10:53 2008 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:1b:2a:12:70:20 Cause=Max Retrasmission
23 Tue Jun 10 08:10:53 2008 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:1b:2a:12:70:20 Cause=Max Retrasmission
24 Tue Jun 10 08:10:48 2008 AP with Base Radio MAC 00:1b:2a:12:71:f0 (NSSF-BLKA05thfloor-AP05B) is unable to associate. The regulatory domain configured on it '-E' does not match the controller's country code: Argentina
25 Tue Jun 10 08:10:47 2008 AP with Base Radio MAC 00:1b:2a:12:70:a0 (NSSF-BLKA06thfloor-AP06B) is unable to associate. The re
Could you pl check the country codes/ regulatory domain on the controller. I think there is a mismatch between -E and -A..
ctioko
Community Member
Thanks so much guys for your insight but it is also interesting to know that an IP conflict caused all those symptoms. the AP Manager interface IP address was allocated to another device in the network.
As stated in my post below, you still have to have a regulatory domain issue. The AP mentioned in the log states the "E" series AP. I would check all APs and verify you have the ones for the proper regulatory domain to insure that you have local RF compliancy.
bbxie
Level 7
Level 7
you can run some debug commands in WLC CLI:
debug mac addr ap-mac-address
debug lwapp events enable
it will tell you what happend for those APs.
You do have a mismatch on regulatory domains. The APs with E in them are for European (ETSI)usage. The A is for US and an N would mean they were for North America excluding the US. You have either changed your regulatory domain on the controller or received APs for the wrong regulatory domain.
