WLAN LLDP capability not sent by an AIR-AP2802I-E-K9
Jave
Can you explain to me why a Cisco AP AIR-AP2802I-E-K9 doesn't send WLAN capability through LLDP TLV type 7 ? Just "bridge" capability is actually sent.
Thanks in advance.
Regards.
Jave
Amazing that Cisco hasn't implemented this natively. Never seen this from other manufacturers. Thanks for the help.
Regards.
9 Replies 9
balaji.bandi
Can you post complete boot log of AP from the time Power on AP, what Code running in it ?
BB
Jave
AP model is: AIR-AP2802I-E-K9
Cisco AP Software, ap3g3-k9w8 Version: 17.9.4.27
I'm going to retrieving boot log.
Jave
Jave
And this is the boot log of one of our AP....
Jave
So ? Any idea ? Because a such behaviour is very damaging for well recognize AP via cdp/lldp neighborough...
It works perfectly well as an AP like that.  If you happen to be using that TLV then you might be out of luck.
marce1000
 - Use latest available software for the AP , and check if that can help ,
 M.
Rich R
I think that's just the way Cisco designed it to work.
You could try 9800 with latest software and see whether that's any different but otherwise it will be a feature enhancement request via your Cisco account team.
I looked at a 9105 running 17.9.4.206 and it's still the same so I think it's safe to assume that Cisco have never implemented that on their APs.  So it will definitely be a feature enhancement request.  You should discuss with your Cisco account team if you really need it.
Jave
Regards.
