WLC 8540 authentication debug for a client
Aleck_Sei
Level 2
Level 2
Hello everyone
We work with a WLC 8540 (version 8.5.161.6) and Cisco 2802 and 3802 AP, and an external Radius server to perform authentication.
We need to trace one or several clients on the WLC to see what messages we receive from the Radius, both for OK and KO authentication.
If we use the commands:
(Cisco Controller) >debug client 00:00:00:00:00:00
(Cisco Controller) >debug aaa all enable
(Cisco Controller) >show debug
The WLC starts flooding the screen with all events, not just my client's. How can we do it?
On the other hand, is there a way to see the authentications of a particular client in the WLC Log history?
Thank you very much
@jorge1976
7 Replies 7
balaji.bandi
In order to enable mobility debugs, use the debug client <MACAddress>, and then use the debug mobility handoff enable command:
(Cisco Controller) >debug client 00:00:00:00:00:00   ( this should be client real MAC address example - debug client 04:f7:e4:ea:5b:66)
(Cisco Controller) >debug mobility handoff enable
here is some reference guide for troubleshooting :
https://mrncciew.com/2014/10/15/wlc-client-debug-part-1/
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/100260-wlc-debug-client.html
https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/112064-wlc-commands.html
BB
Thank you very much for your answer.
I think something is wrong with the WLC. I choose a completely invented MAC with a client passing by and data immediately
begins to appear on the screen... I don't understand what it could be.
(Cisco Controller) >debug client 00:00:00:00:00:aa
(Cisco Controller) >*Dot1x_NW_MsgTask_1: Feb 22 10:58:45.102: [PA] 1x: EAPOL frame with dst MAC 00:a3:8e:fe:c7:40 and BSSID 00:a3:8e:fe:c6:40 discarded
*Dot1x_NW_MsgTask_1: Feb 22 10:58:45.731: [PA] 1x: EAPOL frame with dst MAC a0:e0:af:6a:47:40 and BSSID a0:e0:af:73:8a:c0 discarded
*Dot1x_NW_MsgTask_6: Feb 22 10:58:48.840: [PA] 1x: EAPOL frame with dst MAC 70:db:98:67:27:e0 and BSSID f8:0b:cb:f0:ee:80 discarded
*Dot1x_NW_MsgTask_1: Feb 22 10:58:48.941: [PA] 1x: EAPOL frame with dst MAC 70:df:2f:4a:a3:80 and BSSID 70:df:2f:4d:f6:80 discarded
*Dot1x_NW_MsgTask_5: Feb 22 10:58:49.177: [PA] 1x: EAPOL frame with dst MAC 50:0f:80:a0:91:60 and BSSID 50:0f:80:ac:81:a0 discarded
*Dot1x_NW_MsgTask_5: Feb 22 10:58:49.369: [PA] 1x: EAPOL frame with dst MAC 70:db:98:10:99:80 and BSSID f8:0b:cb:f0:f3:a0 discarded
*Dot1x_NW_MsgTask_4: Feb 22 10:58:50.869: [PA] 1x: EAPOL frame with dst MAC 40:01:7a:8f:89:40 and BSSID 40:01:7a:97:1b:c0 discarded
*Dot1x_NW_MsgTask_4: Feb 22 10:58:51.208: [PA] 1x: EAPOL frame with dst MAC 6c:b2:ae:69:d0:00 and BSSID 6c:b2:ae:89:38:80 discarded
*Dot1x_NW_MsgTask_1: Feb 22 10:58:52.707: [PA] 1x: EAPOL frame with dst MAC 00:a3:8e:d5:18:60 and BSSID 00:a3:8e:d5:1b:e0 discarded
*Dot1x_NW_MsgTask_0: Feb 22 10:58:54.885: [PA] 1x: EAPOL frame with dst MAC 70:df:2f:80:dd:00 and BSSID 70:df:2f:03:4f:c0 discarded
*Dot1x_NW_MsgTask_4: Feb 22 10:58:56.640: [PA] 1x: EAPOL frame with dst MAC 00:2a:10:06:a4:d0 and BSSID 00:81:c4:d1:df:30 discarded
*Dot1x_NW_MsgTask_0: Feb 22 10:58:57.896: [PA] 1x: EAPOL frame with dst MAC 50:0f:80:f7:40:00 and BSSID 38:90:a5:09:2e:80 discarded
*Dot1x_NW_MsgTask_2: Feb 22 10:58:58.115: [PA] 1x: EAPOL frame with dst MAC 70:7d:b9:24:ef:e0 and BSSID 00:a3:8e:fe:b6:80 discarded
*Dot1x_NW_MsgTask_4: Feb 22 10:58:59.067: [PA] 1x: EAPOL frame with dst MAC 6c:b2:ae:53:f2:60 and BSSID 6c:b2:ae:6c:d4:60 discarded
*Dot1x_NW_MsgTask_6: Feb 22 10:58:59.218: [PA] 1x: EAPOL frame with dst MAC 00:27:e3:09:93:60 and BSSID 00:a3:8e:f8:78:40 discarded
*Dot1x_NW_MsgTask_0: Feb 22 10:58:59.374: [PA] 1x: EAPOL frame with dst MAC 00:2c:c8:fc:a0:e0 and BSSID 00:2c:c8:bc:7a:e0 discarded
*Dot1x_NW_MsgTask_6: Feb 22 10:58:59.403: [PA] 1x: EAPOL frame with dst MAC 00:27:e3:09:95:a0 and BSSID 00:a3:8e:fe:c7:60 discarded
Mark Elsen
 - You may leave the particular vty session 'alone' and reconnect to the controller through a new session ; note that client debugs can be analyzed with https://cway.cisco.com/wireless-debug-analyzer , your problem could be due to console messages having been directed to the vty connection too, in that case you may try terminal no monitor in enable mode ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
I did what you suggested but without success. I think something is wrong with the WLC. If I do a debug with an invented address,
and launch the "debug AAA all enable" command, messages from all clients start to flood my screen, not just mine....
If I'm not mistaken, only events related to my address should appear.
                    >... messages from all clients start to flood my screen, not just mine...
  Possibly a bug  look into :  https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
 M.
Rich R
1. "debug AAA all enable" is enabling debug for *all* AAA events, transactions, packets.
2. debug client 00:00:00:00:00:aa should only enable debugs for that client but it's a well known problem that in fact you get many unrelated debugs on newer versions of AireOS.  Using the debug analyzer (link provided by Marce) helps to filter that output for meaningful logs and presents a nicely formatted output.
3. Like Marce said already - update your software.  I recommend 8.5.182.7 or 8.10.183.0 - the current latest 8.5 and 8.10 releases.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Thank you very much!
