WLC code compatibility with AP C9136I-B
Najib Akbari
Level 6
Level 6
I have bunch of AP C9136I-B on C9800 code 17.12.6a and the controller warning message saying the current code does not support 2nd radio to be enabled. i can only upgrade up to 17.12.7a for a while as we have 3700 APs too.
I need your advise :
- is the second radio very important on performance and coverage to be enabled? elaborate a bit on the fundamental of this type of radio
- whats best to do? a work around or something?
@Najib Akbari that is not possible/believable in my opinion.  While a 2600 could theoretically run the same IOS image as the 2700/3700 the controller would not allow it to join because it's not on the list of supported APs (in fact they were end of support after AireOS 8.5 so cannot even join a WLC running 8.10 AireOS).  As Leo says the Wave 1 APs (1700/2700/3700) were left in 17.13.1 by mistake - but you should not use that release.  So stick with 17.12.x for now until you replace your 3700 APs.
Regarding the response you got from TAC (that looks like a reply from the AI bot Sherlock):  it's talking about the 2 modes you can use for the 5 GHz radios on the 9136.  Either combined operating as a single radio (with more spatial streams) or as 2 separate radios each with half the spatial streams. The former is the default in your current software release.  The latter only becomes possible in the future release.  So you are already using both 5GHz radios but they look like a single 8x8 radio.  Splitting them into two 4x4 radios means they would operate on different channels and the AP would create a small cell on one channel (clients close to the AP) and a larger cell on the AP (clients further from the AP) which can possibly accommodate more clients in a high density deployment.  In practice very few people will need this capability and it will require specialist survey and design and also complicates the channel allocations because you need twice as many channels with adequate channel separation (two 5 GHz radios in same AP one will always be on a low channel while the other is always on a high channel).  This is why Sherlock is saying TAC would almost never recommend it.  So stop worrying about it and keep using your APs as they are today.
From the datasheet: https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/nb-06-cat9136-access-point-ds-cte-en.html
Flexible Radio Assignment (FRA) with quad-radio mode (with future software SW upgrade)
FRA allows the access points to intelligently determine the operating mode of serving radios based on the RF environment and traffic demands. The access points can operate in the following modes:
●  Tri-radio mode: One 4x4 6-GHz radio, one 8x8 5-GHz radio, and one 4x4 2.4-GHz radio.
●  Quad-radio mode: One 4x4 6-GHz radio, Dual 4x4 5-GHz radios, and one 4x4 2.4-GHz radio. With four total 4x4 radios (quad-radio) inside the access point, client device capacity can be increased on demand.
The access point’s default mode is tri-radio with 8x8 5-GHz and 4x4 for 6-GHz and 2.4-GHz. It has the ability to split the 8x8 radio into two separate 4x4 5-GHz radios through a future software upgrade, thereby enabling the benefits of FRA while allowing the 2.4- and 6-GHz radios to remain active.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
15 Replies 15
balaji.bandi
If the upgrade is a dependency due to the AP model, that is perfectly understandable.
As I know -
  • Slot 0: 2.4 GHz radio (4x4).
  • Slot 1: Primary 5 GHz radio.
  • Slot 2: Secondary 5 GHz radio.
  • Slot 3: 6 GHz radio (4x4).
5 GHz radio is critical for performance and coverage; it is likely not critical for your environment right now, and leaving it disabled is a perfectly valid operating state
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/technical-reference/cat9136-series-ap-deployment-guide.html
Are you in the migration path ?
BB
Thanks. not sure about migration, but if activating 2nd 5G radio is critical then we should upgrade those 3700 APs
Mark Elsen
  - @Najib Akbari                Ref : https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214855-ios-xe-wireless-feature-list-per-release.html#toc-hId-1595855825
                                         >Quad-radio mode support for 9136 AP
      So you would need 17.13.1 at minimum; in practice 17.15.5 which is adviced
      17.13.1 is not a release for long term use
   Added    : benefits are    - two live, simultaneous client-serving 5 GHz cells — not a fallback radio
                                            more clients possible
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Najib Akbari
Level 6
Level 6
My appologies - i made a mistake on my initial post. i should have put 3700 and not 2700. i edited now
Najib Akbari
Level 6
Level 6
So I have tested before at a different setup the 17.15.5 and WLC shows unsupported AP for AIR-CAP3702I. now im checking the matrix and seems supported ?! maybe it was my mistake and though its not?
  - @Najib Akbari             3700 series is only officially supported till 17.12.3
                                       Ref : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Cisco IOS XE Dublin 17.12.3
17.12.3.31
15.3(3)JPQ2
Cisco Catalyst APs: 9105AX (I/W), 9115AX (I/E), 9117AX (I), 9120AX (I/E/P), 9130AX (I/E), 9136 (I), 9162 (I), 9163 (E), 9164 (I), 9166 (I/D1)
Cisco Aironet APs: 1815 (I/W/M/T), 1830 (I),1840 (I), 1852 (I/E), 1700 (I), 1800i, 2700 (I/E), 2800 (I/E), 3700 (I/E/P), 3800 (I/E/P), 4800 (I)
Najib Akbari
Level 6
Level 6
this is the email I got from the case i opened with TAC and it does not recommend to enable 2nd radio ! :
  - @Najib Akbari           Poor answer,  it's there for a reason and they should also mention from which
                                                           release it can be used,
  M.
Leo Laohoo
2700/3700 is "un-officially" (or accidentally) supported in 17.13.1.
Yep, strange. I have a setup with 17.12.7a and bunch of 2600s and works even though they are not included in the compatibility matrix
Thanks so much for the details, specially about 5Ghz dual radio elaboration. I will eventually go for 17.15.5 ( let me know if you advise a different image ) but nevertheless will stick to one 8X8 5G radio.
yes its from Sherlock!!!!!!! i did not know its a bot!!!!!! hhahahhah good catch
this is another site with 17.12.7a and associated 1700 and 2700 even thou they are not listed in compatibility matrix ...!
  - @Najib Akbari         Note the 2700 ,3700 models (e.g.)   are officially supported till 17.12.3
                                   They work with any 17.12.x version ; the reason for that is that the IOS-XE
                                   code after 17.12.3 was no longer tested on these older access points.
  M.
