WLC keep reloading automictically
Model: AIR-CT5508-K9
Version: 8.1.131.0
Timestamp: Wed Oct 5 19:10:29 2016
SystemUpTime: 0 days 2 hrs 24 mins 8 secs
signal: 11
pid: 1155
TID: 1047323456
Task Name: capwapHATask
Reason: System Crash
si_signo: 11
si_errno: 0
si_code: 1
si_addr: 0x1d66fac8
timer tcb: 0x867
timer cb: 0x102c9228 ('Unknown')
timer arg1: 0x0
timer arg2: 0x0
Long time taken timer call back inforamtion:
Time Stamp: Wed Oct 5 19:10:29 2016
timer cb : 0x102c9228('Unknown')
Duration : 590394 usecs, cbCount= 3
Analysis of Failure:
Software Failed on instruction at :
pc = 0x110d6970 (Unknown), ra = 0x110d6794 (Unknown)
Software Failed while accessing the data located at :0x1d66fac8
NETWORKERS_APAC@publicisgroupe hi, upgrade the OS to recommended version.8.5.182.0. make sure your all Access points are compatible to the new OS version before upgrade.
update--- special release version 8.5.182.7
https://software.cisco.com/download/specialrelease/9a6a7cf84f9fdf04b95c76e2ac7820e7
https://software.cisco.com/download/home/282600534/type/280926587/release/8.5.182.0
Good luck
KB
 Sounds like the bug CSCuw03414. If you can, upgrade it.
Mark Elsen
 - As already mentioned ; software version is way too old , go for :
                  8.5.182.12 (8.5.182.13 for 3504s)
   As denoted in https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
  which these days must be considered mandatory ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Good luck
KB
@Kasun Bandara 8.5.182.0 is out of date and affected by a number of critical bugs (including security vulnerabilities).
As per Marce's reply the correct version for 5508 is now 8.5.182.12.
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#toc-hId-937503882
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
