- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-16-2025 03:05 PM - edited 01-16-2025 03:09 PM
i installed wlc9800 17.16.01 on esxi8 , with dedicated port 10gb
Cisco core switch read it 10gb
Esxi read it 10gb
cisco wlc 9800 read it 1gb
is that normal with WLC 9800 or i miss something ?
WLC#show interfaces gigabitEthernet 1
GigabitEthernet1 is up, line protocol is up
Hardware is vNIC, address is 0050.56bf.d3c3 (bia 0050.56bf.d3c3)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full Duplex, 1000Mbps, link type is auto, media type is Virtual
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:05, output 00:00:03, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 13000 bits/sec, 16 packets/sec
8532 packets input, 893763 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
47 packets output, 11055 bytes, 0 underruns
Output 0 broadcasts (0 multicasts)
1 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Solved! Go to Solution.
- Labels:
Other Routing
Wireless LAN Controller
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-16-2025 03:31 PM
Actually it does not matter. The interfaces will be giga anyway. If you need more than 1 Giga, you can work with port-channel.
But the overall throughput is much less the 10 Giga.
Supports up to 2.1 Gbps of throughput in a centralized wireless deployment (low-throughput profile without SR-IOV)
With a high (enhanced) throughput profile, up to 5 Gbps can be reached on ESXi and KVM with the right set of network cards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-18-2025 07:01 AM
On 9800-CL the name GigabitEthernetX is irrelevant because it's a virtual interface to a virtual switch and there is no direct relationship with the physical interface on the server.
"show int" shows "Hardware is vNIC" and "media type is Virtual" and although it shows "1000Mbps" that has no impact of the rate of traffic through the interface.
That is normal for 9800-CL. You missed the fact that the 9800-CL is not directly connected to the 10G interface as a physical 9800-80 appliance would be.
Please click Helpful if this post helped you and Select as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's and TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's, Best Practices for 9800 WLC's and Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-16-2025 03:16 PM
As the interface is GigabitEthernet, the information you see is correct.
In order to achieve 10Giga the interface should be TenGigabitEthernet
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-16-2025 03:17 PM
how to make it TenGigabitEthernet and the installation read it 1gb
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-16-2025 03:22 PM
Which WLC size did you instaled?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-16-2025 03:23 PM
large , private cloud
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-16-2025 03:31 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-16-2025 03:35 PM
thanks alot for your help , but i have another question does wlc9800 support port channel or from coreswitch side !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-16-2025 03:42 PM - edited 01-16-2025 03:48 PM
Now you got me. Thinking better I dont believe you can configure the WLC with port-channel. You can use trunk but not port-channel.
On this guide we can see that only one interface is given as option for Management
On the following guide they show the configuration for ESXI. See the section "Configuring NIC Teaming on a Virtual Switch"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-18-2025 07:01 AM
