A9K-MPA - 8X10GE not allow online status on asr9001
GRTO
I have an asr 9001 chassis with a module A9K-MPA-8X10GE but its status is not allow online
0/0/0 A9K-MPA-8X10GE NOT ALLOW ONLIN PWR,NSHUT,MON
Does it need a license to activate or is not supported?
Thank you,
tkarnani
please check to see if you are facing this issue with license
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/hardware/Prodlicense/b_asr-9001-s_licensing.html
The Cisco ASR 9001-S Router is a 60 Gbps capacity router with a 40 GE maximum, pluggable ethernet port (MPA0) and two 10 GE fixed SFP+ ports (SFP+0 and SFP+1) enabled on it. The remaining ports MPA1, SFP+2, and SFP+3 are disabled by default. To enable these ports and thus achieve a full bandwidth of 120 Gbps, you need to install the Cisco ASR 9001-S 120G Upgrade License (A9K-9001-120G-LIC).
GRTO
From the version show command I see it is asr9001 chassis, not asr9001-S. Does it make any difference?
RP/0/RSP0/CPU0:asr9k#show version
Fri Mar 1 13:13:49.945 EST
Cisco IOS XR Software, Version 5.3.4[Default]
Copyright (c) 2016 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 2.04(20140227:092320) [ASR9K ROMMON],
asr9k uptime is 1 day, 1 hour, 33 minutes
System image file is "bootflash:disk0/asr9k-os-mbi-5.3.4/0x100000/mbiasr9k-rp.vm"
cisco ASR9K Series (P4040) processor with 8388608K bytes of memory.
P4040 processor at 1500MHz, Revision 2.0
ASR-9001 Chassis
smilstea
The 8x10 card is not supported on the 9001 as it is an 80gbps card and the max bandwidth of each mpa slot is 40gbps.
https://www.cisco.com/c/en/us/products/collateral/routers/asr-9001-router/data_sheet_c78-685687.html for supported MPAs.
Sam
