Advertising directly connected routes to MP-BGP
amonge123
I have a very simple configuration:
vrf VRF-A
 address-family ipv4 unicast
  import route-policy PASS-ALL
  import route-target
   65000:100
  export route-policy PASS-ALL
  export route-target
   65000:100
  pass
end-policy
router bgp 65000
 address-family vpnv4 unicast
 neighbor-group RR
  remote-as 65000
  update-source Loopback0
 neighbor 172.16.5.5
  use neighbor-group RR
 neighbor 172.16.6.6
 vrf VRF-A
  rd 65000:1
  neighbor 10.0.11.2
   remote-as 65001
    route-policy PASS-ALL in
    route-policy PASS-ALL out
Only the routes learned via EBGP are readvertised towards the vpnv4 Route Reflectors:
RP/0/0/CPU0:PE1#show route vrf VRF-A
Sun Jun 22 17:32:00.080 UTC
Codes: C - connected, S - static, R - RIP, B - BGP, (>) - Diversion path
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
       U - per-user static route, o - ODR, L - local, G  - DAGR
       A - access/subscriber, a - Application route, (!) - FRR Backup path
Gateway of last resort is not set
C    10.0.11.0/30 is directly connected, 00:02:20, GigabitEthernet0/0/0/0.11101
L    10.0.11.1/32 is directly connected, 00:02:20, GigabitEthernet0/0/0/0.11101
B    10.0.120.0/24 [20/0] via 10.0.11.2, 00:01:02
B    10.1.1.1/32 [20/0] via 10.0.11.2, 00:01:02
C    10.1.21.0/30 is directly connected, 00:19:13, GigabitEthernet0/0/0/1
L    10.1.21.1/32 is directly connected, 00:19:13, GigabitEthernet0/0/0/1
RP/0/0/CPU0:PE1#show bgp vpnv4 unicast advertised summary
Sun Jun 22 17:32:01.770 UTC
Network            Next Hop        From            Advertised to
Route Distinguisher: 65000:1
10.0.120.0/24      172.16.1.1      10.0.11.2       172.16.5.5
                                   10.0.11.2       172.16.6.6
10.1.1.1/32        172.16.1.1      10.0.11.2       172.16.5.5
Do you know how I can advertise the directly connected routes? Sorry if my question is too basic but I'm kind of stuck.
Thanks!
kszarkowicz
you need to add 'redistribute connected' to your BGP config:
router bgp 65000
 vrf VRF-A
amonge123
I sent the question twice, so I deleted the other discussion. Please answer to this one :)
kszarkowicz
router bgp 65000
 vrf VRF-A
