12-06-2022 05:39 PM
below log was generate in every 5 min.
sh logging last 500
Tue Dec 6 03:09:05.268
Syslog logging: enabled (0 messages dropped, 0 flushes, 0 overruns)
Console logging: level warnings, 398038 messages logged
Monitor logging: level debugging, 0 messages logged
Trap logging: level informational, 638893 messages logged
Logging to 172.29.8.6, 638893 message lines logged
Buffer logging: level debugging, 643707 messages logged
Log Buffer (2097152 bytes):
RP/0/RSP0/CPU0:Dec 6 01:38:56.558 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/libbag.dll 0x0cbf1000 0x0000c000 0x0cbfd000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.559 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /asr9k-os-5.3.4.CSCvf24118-1.0.0/0x100305/lib/libcshm.dll 0x0cc00000 0x00004000 0x0cc04000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.559 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/liblrdinv.dll 0x0cd5b000 0x00008000 0x0cd63000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.560 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/libnrsutils.dll 0x0cde7000 0x00005000 0x0cdec000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.560 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/asr9k-base-5.3.4/0x100305/lib/liblrdplatinv.dll 0x0cdf8000 0x00007000 0x0cdff000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.560 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/libnrs.dll 0x0ce6d000 0x00009000 0x0ce76000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.561 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /asr9k-os-5.3.4.CSCvf24118-1.0.0/0x100305/lib/lib_rrwlock.dll 0x0ce77000 0x00004000 0x0ce7b000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.561 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-fwding-5.3.4/0x100305/lib/libifmgr.dll 0x0d211000 0x0004c000 0x0d25d000 0x00003000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.562 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-fwding-5.3.4/0x100305/lib/libim_util.dll 0x0d288000 0x0002c000 0x0d2b4000 0x00008000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.562 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/libasync.dll 0x0d2f2000 0x0000d000 0x0d2ff000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.563 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/libcbp.dll 0x0d31a000 0x00008000 0x0d322000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.563 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /asr9k-os-5.3.4.CSCvf24118-1.0.0/0x100305/lib/libprotect_server.dll 0x0d364000 0x0000a000 0x0d36e000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.563 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/librpc.dll 0x0d36f000 0x00008000 0x0d377000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.564 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/libgsched_v2.dll 0x0d378000 0x00008000 0x0d380000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.564 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/libsysdbbackend.dll 0x0d5a8000 0x00005000 0x0d5ad000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.565 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/libbackend_sysdb.dll 0x0e49c000 0x00006000 0x0e4a2000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.565 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/libbackend_parser.dll 0x0e4a3000 0x00004000 0x0e4a7000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.566 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-fwding-5.3.4/0x100305/lib/libim_svr.dll 0x0e4e8000 0x00095000 0x0e57d000 0x00017000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.566 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /asr9k-os-5.3.4.CSCvf24118-1.0.0/0x100305/lib/libplatform_pfi_im.dll 0x0e5b2000 0x00001000 0x0e5b3000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.567 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/libimdr.dll 0x0e638000 0x00009000 0x0e641000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.567 : dumper[60]: %OS-DUMPER-6-REMOVE_OLDEST : Removing dump dumper_harddisk:/dumper/mibd_entity_332.20220918-124605.node0_RSP0_CPU0.x86.Z as we can have only limited number of cores in fallback path
RP/0/RSP0/CPU0:Dec 6 01:38:56.567 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-fwding-5.3.4/0x100305/lib/libpfi_util.dll 0x0e6b2000 0x00003000 0x0e6b5000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.568 : dumper[60]: %OS-DUMPER-7-DLL_INFO : /disk0/iosxr-infra-5.3.4/0x100305/lib/libdcl.dll 0x0e9a4000 0x0000b000 0x0e9af000 0x00001000 0
RP/0/RSP0/CPU0:Dec 6 01:38:56.574 : dumper[60]: %OS-DUMPER-6-FALLBACK_CHOICE : Fall back choice: 4(dumper_harddisk:/dumper) in use
RP/0/RSP0/CPU0:Dec 6 01:38:56.575 : dumper[60]: %OS-DUMPER-5-CORE_FILE_NAME : Core for process pkg/bin/ifmgr at harddisk:/dumper/ifmgr_249.20221206-013856.node0_RSP0_CPU0.x86.Z on local_node
RP/0/RSP0/CPU0:Dec 6 01:39:07.607 : dumper[60]: %OS-DUMPER-7-XFER_CORE : Tranferring core to configured location
RP/0/RSP0/CPU0:Dec 6 01:39:07.607 : dumper[60]: %OS-DUMPER-7-SIGNAL_OS : All files copied. Now signalling the OS (line 4072)
RP/0/RSP0/CPU0:Dec 6 01:39:07.607 : dumper[60]: %OS-DUMPER-5-DUMP_SUCCESS : Core dump success
RP/0/RSP0/CPU0:Dec 6 01:39:07.627 : BM-DISTRIB[1182]: %L2-BM-6-REPL_RETRY : Replication failed for member Te0/0/0/16 (0x000004c0) of bundle Bundle-Ether3. Operation will be retried. Check "show bundle status" for more details.
RP/0/RSP0/CPU0:Dec 6 01:39:07.627 : BM-DISTRIB[1182]: %L2-BM-6-REPL_RETRY : Replication failed for member Te0/0/0/15 (0x00000480) of bundle Bundle-Ether3. Operation will be retried. Check "show bundle status" for more details.
RP/0/RSP0/CPU0:Dec 6 01:39:07.627 : BM-DISTRIB[1182]: %L2-BM-6-REPL_RETRY : Replication failed for member Te0/0/0/14 (0x00000440) of bundle Bundle-Ether3. Operation will be retried. Check "show bundle status" for more details.
RP/0/RSP0/CPU0:Dec 6 01:39:07.627 : BM-DISTRIB[1182]: %L2-BM-6-REPL_RETRY : Replication failed for member Te0/0/0/2 (0x00000140) of bundle Bundle-Ether3. Operation will be retried. Check "show bundle status" for more details.
RP/0/RSP0/CPU0:Dec 6 01:39:07.637 : aib[112]: vkg_pmlib_aib_pfi_ifh_connect imc server bind failed reason 'ifmgr' detected the 'warning' condition 'Failed to contact the server'
RP/0/RSP0/CPU0:Dec 6 01:39:07.637 : dumper[60]: %OS-DUMPER-7-DUMP_REQUEST : Dump request for process pkg/bin/icpe_satmgr
RP/0/RSP0/CPU0:Dec 6 01:39:07.643 : dumper[60]: %OS-DUMPER-7-DUMP_ATTRIBUTE : Dump request with attribute 7 for process pkg/bin/icpe_satmgr
RP/0/RSP0/CPU0:Dec 6 01:39:07.644 : dumper[60]: %OS-DUMPER-4-SIGSEGV : Thread 1 received SIGSEGV - Segmentation Fault
RP/0/RSP0/CPU0:Dec 6 01:39:07.644 : dumper[60]: %OS-DUMPER-4-SIGSEGV_INFO : Accessed BadAddr 0x1 at PC 0x107a16d2. Signal code 1 - SEGV_MAPPER. Address not mapped.
RP/0/RSP0/CPU0:Dec 6 01:39:07.644 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 561476 (pkg/bin/icpe_satmgr)
RP/0/RSP0/CPU0:Dec 6 01:39:07.645 : dumper[60]: %OS-DUMPER-7-PROC_PAGES : Process memory pages 1208
RP/0/RSP0/CPU0:Dec 6 01:39:07.648 : dumper[60]: %OS-DUMPER-6-FALLBACK_CHOICE : Fall back choice: 0(harddisk:/dumper) in use
RP/0/RSP0/CPU0:Dec 6 01:39:07.648 : dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : EDI ESI EBP(fp) EXX
RP/0/RSP0/CPU0:Dec 6 01:39:07.648 : dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : R0 00000000 107d2874 041fb808 fca7ccd0
RP/0/RSP0/CPU0:Dec 6 01:39:07.648 : dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : EBX EDX ECX EAX
RP/0/RSP0/CPU0:Dec 6 01:39:07.648 : dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : R4 107d2a00 1124cd58 00000000 00000001
RP/0/RSP0/CPU0:Dec 6 01:39:07.648 : dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : EIP(pc) CS EFL ESP
RP/0/RSP0/CPU0:Dec 6 01:39:07.648 : dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : R8 107a16d2 000000f3 00001246 041fb808
RP/0/RSP0/CPU0:Dec 6 01:39:07.648 : dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : SS
RP/0/RSP0/CPU0:Dec 6 01:39:07.648 : dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : R12 000000fb
RP/0/RSP0/CPU0:Dec 6 01:39:07.649 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #0 0x107a16d2
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #1 0x1079ef98
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #2 0xd22a7e2
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #3 0xd22a8d2
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #4 0xd21caa7
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #5 0xd21cb18
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #6 0xd21e25a
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #7 0x1079b55e
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #8 0xba93a60
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #9 0xba94204
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #10 0xba947a3
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #11 0xba8ee7c
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #12 0xba906d5
RP/0/RSP0/CPU0:Dec 6 01:39:07.716 : dumper[60]: %OS-DUMPER-6-TRACE_BACK : #13 0xba8e7a8
RP/0/RSP0/CPU0:Dec 6 01:39:07.718 : dumper[60]: %OS-DUMPER-6-INSTALL_PKG : iosxr-gcp-fwding-5.3.4.CSCvd76488 V 1.0.0[SMU] Cisco Systems By iox-lnx-007 in /san1/EFR/smu_r53x_5_3_4/workspace for pie at /install/iosxr-gcp-fwding-5.3.4.CSCvd76488-1.0.0 Built on Thu Mar 30 04:54:08 YGN 2017
RP/0/RSP0/CPU0:Dec 6 01:39:07.718 : dumper[60]: %OS-DUMPER-6-INSTALL_PKG : iosxr-gcp-fwding-5.3.4.CSCvb62919 V 1.0.0[SMU] Cisco Systems By iox-lnx-007 in /san1/EFR/smu_r53x_5_3_4/workspace for pie at /install/iosxr-gcp-fwding-5.3.4.CSCvb62919-1.0.0 Built on Sat Dec 17 18:07:37 YGN 2016
RP/0/RSP0/CPU0:Dec 6 01:39:07.718 : dumper[60]: %OS-DUMPER-6-INSTALL_PKG : iosxr-gcp-fwding-5.3.4.CSCvb72705 V 1.0.0[SMU] Cisco Systems By iox-lnx-007 in /san1/EFR/smu_r53x_5_3_4/workspace for pie at /install/iosxr-gcp-fwding-5.3.4.CSCvb72705-1.0.0 Built on Thu Dec 1 05:54:24 YGN 2016
RP/0/RSP0/CPU0:Dec 6 01:39:07.718 : dumper[60]: %OS-DUMPER-6-INSTALL_PKG : iosxr-gcp-fwding V 5.3.4[Default] Cisco Systems By iox-lnx-005 in /auto/srcarchive15/production/5.3.4/asr9k-px/workspace for pie at /install/iosxr-gcp-fwding-5.3.4 Built on Tue Oct 4 16:37:38 YGN 2016
RP/0/RSP0/CPU0:Dec 6 01:39:07.718 : dumper[60]: %OS-DUMPER-6-INSTALL_PKG : iosxr-common-pd-fib-5.3.4.CSCvb57301 V 1.0.0[SMU] Cisco Systems By iox-lnx-007 in /san1/EFR/smu_r53x_5_3_4/workspace for pie at /install/iosxr-common-pd-fib-5.3.4.CSCvb57301-1.0.0 Built on Wed Jul 12 18:15:58 YGN 2017
RP/0/RSP0/CPU0:Dec 6 01:39:07.718 : dumper[60]: %OS-DUMPER-6-INSTALL_PKG : iosxr-common-pd-fib-5.3.4.CSCvd76488 V 1.0.0[SMU] Cisco Systems By iox-lnx-007 in
12-06-2022 05:42 PM
it is ASR 9010 RP440SE
12-07-2022 09:27 AM
I would need to know more data like the show installed active summary to decode the crash, and also a complete crash log, it looks like in the above I have parts of 2 different crashes. I would suggest opening a TAC case if possible.
As an aside 5.3.4 is rather old and no longer supported, the last release for RSP440 is 6.4.2.
Sam
12-08-2022 06:32 AM
thank you info but this device our BNG device, which cannot be upgraded at present. I will grab more logs to let you know
12-08-2022 06:31 AM
