ASR 9010 SNMP detail
saikchak1
Hi Everyone,
This is my first post in this CISCO community, so again HELLO.
Regarding the SNMP traps in ASR 9010 (I use IOS-XR:4.1.2), which trap is used to get notifications when the transceiver power is low or below the threshold, also is there a document which explains what each trap does(in detail)? I have already read the
"Cisco ASR 9000 Series Aggregation Services Router System Management Command Reference, Release 4.1"  which was good but not so informative on the topic of SNMP.
Best Regards
Saikat
Alexei Kiritchenko
Hello Saikat,
The list of supported notifications can be found here "MIB Notification Names in the Cisco ASR 9000 Series Routers"
http://www.cisco.com/en/US/docs/routers/asr9000/mib/guide/asr9kmib3.html#wp1602338
The power should be under CISCO-ENTITY-SENSOR-MIB
Configure "snmp-server traps sensor", then entSensorThresholdNotification  trap should be raised when sensor threshold is crossed.
/A
5 Replies 5
Alexei Kiritchenko
Hello Saikat,
/A
thank you so much, this document is good.
Is there a way of changing the default threshold value "entSensorThreshold Table"? If so whats the procedure.
Im using XFP-10GER-192IR+ for inter-site connection.
For eg.
The output of  "show controllers te phy"
Thresholds:                    Alarm High                   Warning High                              Warning Low                                        Alarm Low
              Temperature:               83.000                 80.000                                     -10.000                                                -13.000
                  Voltage:           0.000 Volt                   0.000 Volt                                0.000 Volt                                            0.000 Volt
                     Bias:        130.000 mAmps              120.000 mAmps                       20.000 mAmps                                     10.000 mAmps
           Transmit Power:  5.012 mW (7.00 dBm)       2.512 mW (4.00 dBm)              0.339 mW (-4.70 dBm)                          0.170 mW (-7.70
            Receive Power:  1.585 mW (2.00 dBm)       0.794 mW (-1.00 dBm)             0.026 mW (-15.80 dBm)                         0.013 mW (-18.
Will these values be referred by the entity-sensor MIB or the default ones "entSensorThreshold Table"
which are mentioned inside the MIB specification guide will be used?
Thanks in advance.
Best Regards
Saikat
Message was edited by: Saikat Chakraborty
Hi Saikat,
no, threshold values can not be changed.
Yes, these threshold should be used and I’d expect both all of them to generate a trap.
/A
thanks....
