ASR bvi interface and port monitor
feableee123
I have few subnets connected to asr subinterfaces - then strip off vlan information, and all subnets are in the same bridge domain and have common
gateway -BVI 100.
What I need is monitor all IP traffic that pass through Gateway to internet. With L3 interface I used to configure "port monitor" but with BVI I dont have
monitor port option. I Considered also loopback interface except BVI but it dont support monitor port either.
Configuration is below. Any suggestions about monitor that traffic ?
subnet (vlan 100) ----------  g0/1/0/1.100 l2transport --
        |----------- BVI 100 (Gateway) ------
subnet (vlan 200) ----------  g0/1/0/1.200 l2transport --
interface GigabitEthernet0/1/0/1.100 l2transport
encapsulation dot1q 100
rewrite ingress tag pop 1 symmetric
nterface GigabitEthernet0/1/0/1.200 l2transport
interface BVI100
ipv4 address 192.168.0.1 255.255.255.0
l2vpn
bridge group TEST
  bridge-domain te1
   interface GigabitEthernet0/1/0/1.200
   routed interface BVI100
regards
Alexei Kiritchenko
Hello Jarek,
You can configure a monitor session under l2transport subinterface
ASR9000/XR: How to use Port Spanning or Port Mirroring
https://supportforums.cisco.com/docs/DOC-15772
Regads,
/A
Alexei Kiritchenko
Hello Jarek,
Regads,
/A
Do You know if you configure two l2transport subinterfaces  (vlan 100 and 200) as a source  than on destination port you have traffic encapsulated with 8021.q tags 100 and 200 ? Do I need another switch connected to destination port to correctly gather traffic from both vlans ?
regards,
traffic would be mirrored as is, so VLAN tags would be preserved. Either you can connect you sniffer directly to the destination port and you’d see traffic with vlans 100 and 200 or you may do kind of r-span and yet push 2nd tag to allow your mirrored traffic to go though set of switches to the sniffer.
r-span example:
interface TenGigE0/2/0/0.3 l2transport
monitor-session akspan
destination interface GigabitEthernet0/7/1/17.1095
interface GigabitEthernet0/7/1/17.1095 l2transport
encapsulation dot1q 1095
Here I mirror VLAN 100 traffic and yet we push 2nd tag when packets are sent out of GigabitEthernet0/7/1/17.1095, so we’d have on wire {1095,100} tags.
/A
Please visit http://cisco.com/go/testdrive or contact your account rep to schedule nV tech demo.
