Showing results forĀ
Search instead forĀ
Did you mean:Ā
ASR9K Lost configuration after reboot
Hamza_MX
Hello
We have an ASR9K that loose comitted configuration after a reboot .
We have the following log :
RP/0/RSP0/CPU0:Apr 19 14:45:31.690 : cfgmgr-rp[167]: %MGBL-CONFIG-6-STARTUP_ALTERNATE : Configuration Manager can not find any configuration to apply from the alternate source '/harddisk:/no-config'. Default configuration will be applied.
2 Accepted Solutions
tkarnani
did someone try to perform password recovery and did not revert the rommon variable?
https://community.cisco.com/t5/service-providers-documents/asr9000-xr-how-to-reset-a-lost-password-password-recovery-on-ios/ta-p/3109412
Overriding the Base configuration in XR:
Step 1
In rommon set the following variable:
rommon> IOX_CONFIG_FILE=/harddisk:/no-config
we can check the following output to confirm "more nvram:/classic-rommon-var location 0/<active rp>/CPU0"
Hello ,
Thank @tkarnani  for you help .
I unset the ROMMON config file and all is good now.
tkarnani
Step 1
Hello ,
muhsini.sefu
Can lost configuration be recovered after software upgrades example for NCS-560-7?
