03-20-2016 06:58 PM
I am in process of installing XR image on asr9k and I have a tar file on my laptop. what i need to do in order to install this on asr9k. i will be connecting on management ethernet : I have a tar file with me and as per my understanding :
# install add tar tftp://<ip add of local laptop>/<SW file name>
my Q is :
1. this command will install the OS or just put the image on router ?
2. if this will just copy the image on router, where will it go ? on disk0 ?
3. Now in order to install one by one packages ..is it correct that I should use 'install activate disk0:<pie 1> <pie 2> ?
thanks in adv
Solved! Go to Solution.
03-22-2016 11:24 PM
Yes...this will work...One minor change for "install add /harddisk:/ASR9K-iosxr-px-5.3.3.tar". You need to use "install add tar /harddisk:/ASR9K-iosxr-px-5.3.3.tar"
Also, for install activate, you can use the install id of "install add": "install activate id <>"
Santosh
03-21-2016 08:42 PM
I don't know the answer.
But I did find this great article about the entire process.
Upgrading and Managing Software on Cisco ASR 9000 Series Router
03-21-2016 08:51 PM
Hi Arjun,
This will just add the binaries to the router. You need to "install activate <pie names>" to activate the OS.
Copy can be done anywhere in the router(disk0, harddisk). With copy command you need to specify the destination location in the router
Yeah, this will activate the packages. However you can use regular expressions to avoid pasting long list of pies. Something like "install activate disk0:*5.3.3*:, incase you want to activate 5.3.3.
Santosh
03-22-2016 11:21 PM
Hi Santosh,
Many Thanks -
can you plz confirm if these 3 commands will do the job ?
RP/0/RSP0/CPU0:ios(admin)copy tftp://<IP ADD>/FileName harddisk:
RP/0/RSP0/CPU0:ios(admin)#install add /harddisk:/ASR9K-iosxr-px-5.3.3.tar
RP/0/RSP0/CPU0:ios(admin)#install activate disk0:asr9k-services-px-5.3.3 disk0:asr9k-services-infra-5.3.3 disk0:asr9k-fpd-px-5.3.3 disk0:asr9k-optic-px-5.3.3 disk0:asr9k-doc-px-5.3.3
thanks in adv
03-22-2016 11:24 PM
Santosh
03-24-2016 07:09 AM
Hi Santosh
Small clarification - I see a USB port as will on router.
can you please tell, Which command can be used to transfer file from usb to harddisk.
Thankyou
03-24-2016 10:24 AM
Hi Arjun,
Copy usb:/<file_name> harddisk:/ can be used to copy the file from usb to harddisk:.
Santosh
03-28-2016 07:43 AM
Hi Santosh
today I tried to use USB on a 9k but looks like there are some limitations with resoect to USB file system. Do i need to have a particular file system on USB drive ? how do I do that ?
03-28-2016 11:52 AM
Format it FAT32 and it should be fine.
03-29-2016 11:09 AM
hi philip
i tried but asr9k still did not recognise usb. looks like it needs a linux file system..now sure how to get it.
my pen drive does not show FAT 16 also..
03-29-2016 11:41 AM
How about formatting it in the ASR itself. It must use a compatible filesystem then.
format usb:
04-17-2019 09:41 AM
The solution don t work.
04-07-2021 03:11 AM
show media
copy disk2:/file harddisk:/file
03-22-2016 09:34 AM
for 3) you can also admin install activate id X where X is the install operation in which you added the packages. This can save you some time if you installed several pies in one operation.
