02-20-2021 04:21 AM
Our lab no longer has redundant pairs of RSP880's as a RSP880-SE had to be moved to another location for a new lab.
We're trying to do some interoperability using A9K-8X100GE-TR. A single RSP880 will be rate limited so we need 2. Are there any issues mixing SE and TR RSP880 for testing purposes?
02-20-2021 05:28 AM
02-20-2021 08:22 AM
Hi Balaji, thanks for the reply but I don't see anything in that link that states we can mix. I read that you can mix "cards/modules". I translate that as RSP880-SE can mix with 4X100GE-TR, for example.
02-21-2021 02:21 AM
i was in the impression it was -LT (i have closed look again - you are right TRF i did not see any information).
02-20-2021 01:09 PM
I really doubt that because the RSPs or RPs are replicating data between Active and Standby unit. The must be identical based on my knowledge.
