01-13-2024 10:22 AM
I came through a situation for the past couple of days:
I have 2 Firewall stages, Core and Perimeter (each stage with 2xFPR3110):
Scenario:
-My perimeter firewall is point-to-point connected on a /27 public subnet with my Border router that's interconnecting with the ISP [PerimeterFW ---/27 public subnet ---> MY Border router --- /30 public subnet ---> ISP Router]
From the /27 subnet, i used one IP on Perimeter FW interface, and one on MY Border router
- The request was the following: the user wants to connect on tcp/22 using on one of the remaining IPs from the public /27 subnet, and to be redirected to an internal resource.
For this request i've performed DNAT. did access rule, made sure that i do have a valid route towards internal resource
The point here is that when i test with packet tracer, the flow is allowed, but in reality its not working.
Another funny thing is that for testing purpose i've allowed ICMP on the public IP from the perimeter firewall and is not working. It looks like the Access policies are not doing anything. I ve also allowed icmp from platform settings and the same result not working.
I mention that the segment between ISP router and Perimeter firewall (that /27 is router properly, as i can ICMP reach MY border router on that interface)
I mention that i ve double checked the zones, routing and access policies.
Please help
01-13-2024 10:24 AM
Scenario:
Please help
01-13-2024 10:39 AM
what FMC and FTD Version ?
i would cross check the configuration one more time -
you confirmed from out side packet coming in ISP router, but you do not see the traffic in FW ? Do you have routing correctly from ISP Router to route back where the packet need to go when the incoming packet coming in ?
what ISP router, can you post configuration and routing information.
If the packet coming in to FW - i am sure you see on FMC either drop or allowed. (not necessary to have ACL).
try packet-tracer and post the output here.
check below guide for reference :
https://rayka-co.com/lesson/cisco-ftd-nat-configuration/
01-13-2024 10:50 AM
I am using FMC version 7.3.1 / FTDs version 7.3.1
- I have on Perimeter firewall a default route towards remote p2p IP with MY Border router and static route to LAN resource subnet via interconnect with Core Fw IP.
packet tracer :
> packet-tracer input PO-INTERNET tcp 109.166.151.139 22 188.241.73.100 22 detailed
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Elapsed time: 15532 ns
Config:
nat (PO-INTERNET,INTERCONNECT) source static Idemia+GTS Idemia+GTS destination static host_188.241.73.100 dmz_sftp_srv_200.60 service SVC_12884936190 SVC_12884936190
Additional Information:
NAT divert to egress interface INTERCONNECT(vrfid:0)
Untranslate 188.241.73.100/22 to 10.10.200.60/22
Phase: 2
Type: OBJECT_GROUP_SEARCH
Subtype:
Result: ALLOW
Elapsed time: 0 ns
Config:
Source Object Group Match Count: 1
Destination Object Group Match Count: 5
Object Group Search: 0
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Elapsed time: 0 ns
Config:
access-group CSM_FW_ACL_ global
access-list CSM_FW_ACL_ advanced permit ip ifc PO-INTERNET any any rule-id 268435473
access-list CSM_FW_ACL_ remark rule-id 268435473: ACCESS POLICY: PerimeterFW - Mandatory
access-list CSM_FW_ACL_ remark rule-id 268435473: L7 RULE: GeoLocation-BLOCK
This packet will be sent to snort for additional processing where a verdict will be reached
Forward Flow based lookup yields rule:
in id=0x14fde4efbfd0, priority=12, domain=permit, deny=false
hits=1, user_data=0x14fdc3bb1c40, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, ifc=PO-INTERNET(vrfid:0)
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, ifc=any,
src nsg_id=none, dst nsg_id=none
dscp=0x0, input_ifc=any, output_ifc=any
Phase: 4
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Elapsed time: 0 ns
Config:
class-map class-default
match any
policy-map global_policy
class class-default
set connection advanced-options UM_STATIC_TCP_MAP
service-policy global_policy global
in id=0x14fde50e2480, priority=7, domain=conn-set, deny=false
hits=66, user_data=0x14fde67135c0, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
dscp=0x0, input_ifc=PO-INTERNET(vrfid:0), output_ifc=any
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Elapsed time: 0 ns
Config:
Static translate 109.166.151.139/22 to 109.166.151.139/22
in id=0x14fde4a00c60, priority=6, domain=nat, deny=false
hits=15, user_data=0x14fde4366080, cs_id=0x0, flags=0x0, protocol=6
src ip/id=109.166.151.139, mask=255.255.255.255, port=0, tag=any
dst ip/id=188.241.73.100, mask=255.255.255.255, port=22, tag=any
dscp=0x0, input_ifc=PO-INTERNET(vrfid:0), output_ifc=INTERCONNECT(vrfid:0)
Phase: 6
Type: NAT
Subtype: per-session
Result: ALLOW
Elapsed time: 0 ns
Config:
in id=0x14fddfdd92d0, priority=0, domain=nat-per-session, deny=false
hits=109, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=6
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Elapsed time: 0 ns
Config:
in id=0x14fde4f59160, priority=0, domain=inspect-ip-options, deny=true
hits=100, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: NAT
Subtype: rpf-check
Result: ALLOW
Elapsed time: 16591 ns
Config:
out id=0x14fde1895f90, priority=6, domain=nat-reverse, deny=false
hits=18, user_data=0x14fde625c040, cs_id=0x0, use_real_addr, flags=0x0, protocol=6
dst ip/id=10.10.200.60, mask=255.255.255.255, port=22, tag=any
Phase: 9
Type: NAT
Result: ALLOW
Elapsed time: 17650 ns
Config:
Reverse Flow based lookup yields rule:
hits=111, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=6
Phase: 10
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Elapsed time: 0 ns
Config:
in id=0x14fde4ab96f0, priority=0, domain=inspect-ip-options, deny=true
hits=10095, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
dscp=0x0, input_ifc=INTERCONNECT(vrfid:0), output_ifc=any
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Elapsed time: 8119 ns
Config:
New flow created with id 13314, packet dispatched to next module
Module information for forward flow ...
snp_fp_inspect_ip_options
snp_fp_tcp_normalizer
snp_fp_snort
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Module information for reverse flow ...
snp_fp_translate
snp_fp_snort
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Phase: 12
Type: EXTERNAL-INSPECT
Subtype:
Result: ALLOW
Elapsed time: 16944 ns
Config:
Application: 'SNORT Inspect'
Phase: 13
Type: SNORT
Subtype: appid
Result: ALLOW
Elapsed time: 27637 ns
Config:
service: (0), client: (0), payload: (0), misc: (0)
Phase: 14
Type: SNORT
Subtype: firewall
Result: ALLOW
Elapsed time: 82070 ns
Config:
Network 0, Inspection 0, Detection 2, Rule ID 268435475
Starting rule matching, zone 2 -> 1, geo 0 -> 0, vlan 0, src sgt: 0, src sgt type: unknown, dst sgt: 0, dst sgt type: unknown, user 9999997, no url or host, no xff
Matched rule ids 268435475 - Allow
Phase: 15
Type: INPUT-ROUTE-LOOKUP-FROM-OUTPUT-ROUTE-LOOKUP
Subtype: Resolve Preferred Egress interface
Result: ALLOW
Elapsed time: 5295 ns
Config:
Found next-hop 10.11.11.1 using egress ifc INTERCONNECT(vrfid:0)
Phase: 16
Type: ADJACENCY-LOOKUP
Subtype: Resolve Nexthop IP address to MAC
Result: ALLOW
Elapsed time: 1412 ns
Config:
Found adjacency entry for Next-hop 10.11.11.1 on interface INTERCONNECT
Adjacency :Active
MAC address 6879.099f.edb0 hits 16 reference 1
Result:
input-interface: PO-INTERNET(vrfid:0)
input-status: up
input-line-status: up
output-interface: INTERCONNECT(vrfid:0)
output-status: up
output-line-status: up
Action: allow
Time Taken: 191250 ns
I mention that the routing on MY Border router is really simple: default route towards ISP and the /27 network is known as connected as an ip from that subnet is connected on my interface towards the perimeter firewall
01-13-2024 10:44 AM
can you draw the topology
thanks
MHM
01-13-2024 10:56 AM
Each stage two FW' are it config as HA or as cluster?
Draw topolgy will be big help for us to get issue here
MHM
01-13-2024 11:00 AM
i didn't finished the HA configuration, so for this case/ purpose, we ll consider each stage as only one firewall member
01-13-2024 10:58 AM
Sure, scenario and request below:
01-13-2024 10:58 AM
AND i forgot to mention that i also have a default route on Perimeter FW pointing to 77.1.1.2
01-13-2024 11:10 AM
The perimeter FW will do NATing of DMZ into internet Zone IP ?
MHM
01-13-2024 11:23 AM
On the perimeter FW i did the DNAT rule regarding IN traffic, from what i know i don t need to do the oposite nat right?
01-13-2024 11:27 AM
Can I see NAT you use via FMC
MHM
01-13-2024 11:30 AM
01-13-2024 11:24 AM
This IP confuse me ? Where is this IP?
MHM
01-13-2024 11:27 AM
This IP is from that /27 public subnet between perimeter Firewall and border router. Is the IP chosen by sysadmins to be exposed with NAT and accessed in order to reach the DMZ host 10.10.200.60
On my diagram i didnt put the real IPs
