Ebgp between ios and ios xr
TaimurKhan
hello all
I am new to ios xr and after some study i started building a small lab
the lab is to bring eBgp neighborship between one regular ios and ios xr. they are connected directly
cisco ios xr  interface ip is 192.168.15.1/24
cisco ios interface ip is 192.168.15.2/24
they both can ping each others.
My configs is below.
ios XR
interface GigabitEthernet0/0/0/1
ipv4 address 192.168.15.1 255.255.255.0
no shut
route-policy PASS
pass
end-policy
router bgp 1
address-family ipv4 unicast
neighbor 192.168.15.2
remote-as 5
route-policy PASS in
route-policy PASS out
Regular IOS
interface Loopback0
ip address 5.5.5.5 255.255.255.255
interface FastEthernet2/0
ip address 192.168.15.2 255.255.255.0
no shut
router bgp 5
bgp log-neighbor-changes
redistribute connected
neighbor 192.168.15.1 remote-as 1
with this config i am unable to bring the neighborship up.
please check.
Harold Ritter
Hi @TaimurKhan ,
Normally, XR should set the BGP router ID automatically if there is at least one ipv4 address configured locally. It looks like it might not be able to do so in your case for some reason. Try forcing the router ID with the following command:
router bgp 1
 bgp router-id 192.168.15.1
By the way, it is a best practice to set the BGP router ID explicitly, rather than let BGP pick one automatically.
6 Replies 6
balaji.bandi
The question confusing here ? heading says EIGRP and Content is BGP
Are you Looking BPG config - can you able to ping each other Routers ?
Advise -  use source interface and on IOS activate command.
check below guide can help you :
https://community.cisco.com/t5/networking-knowledge-base/bgp-basic-configuration-on-ios-xr-ibgp-and-ebgp/ta-p/3145638
BB
thanks for the reply
heading of the topic is Ebgp not eigrp
i have gone through that full article document and followed it but it is not coming up. although i am able to make eigrp neighborship up.
Harold Ritter
Hi @TaimurKhan ,
router bgp 1
thanks alot
I have spent hours on fixing this issue. now it is up. thanks once again.
You are very welcome @TaimurKhan . There is a few ways you could have gone for troubleshooting this issue.
1. show bgp ipv4 unicast neighbor x.x.x.x detail (as mentioned by @tkarnani )
2. debug bgp (after configuring "logging console debug"). This a good option for lab testing, but need to use it with caution if it is for a production network.
tkarnani
on XR
show bgp ipv4 unicast neighbor x.x.x.x detail << this output usually gives some clue as to why its down
