ā05-02-2019 07:15 AM
Hello experts
We currently have an ASR 9904 that has a RSP440-TR and a 24*10GE-TR Line card.We bought another RSP440-TR to put in the chassis . Can we put the RSP in when the router is running ? and Do we have to do any configuration for new RSP or the process is done automatically without any changes ?
I am really appreciate if someone provide me with any help and tutorial video or helpful documents for installing RSP-440
Thank you,
Solved! Go to Solution.
ā05-02-2019 09:57 AM
yes you can install as standby while the router is running
ā05-02-2019 07:53 AM
installing a standby RSP requires no additional configuration.
just plug it in and it will synchronize with the active
ā05-02-2019 08:02 AM
ā05-02-2019 09:23 AM
Thank you for your help
We can not reload the router or shut it down because it is under load .Can we do that when router is running ?
ā05-07-2019 04:36 PM
Yes, you can insert the new RSP and monitor using show platform or admin show platform, also show redundancy in order to validate the RSP Card operation.
