%IP-TCP_NSR-3-OUT_OF_SYNC @ ASR9001 nV Edge
dfranjoso
What does "%IP-TCP_NSR-3-OUT_OF_SYNC  One or more NSR control messages could not be delivered to partner TCP" message means in a two ASR9001 nV Edge cluster ?
Does it means that there are problems with both RSP TCP stacks sincronization (control-plane) ? How can i confirm that the Cluster is in sync ?
Thanks !
David
6 Replies 6
smailmilak
Level 4
Level 4
I had the same problem on 4 ASR-s, but I checked a few minutes ago and now it's gone!!
And show redundancy showed this:
v6-routing       0/RSP0/CPU0     0/RSP1/CPU0     Ready
mcast-routing    0/RSP0/CPU0     0/RSP1/CPU0     Ready
netmgmt          0/RSP0/CPU0     0/RSP1/CPU0     Ready
v4-routing       0/RSP0/CPU0     0/RSP1/CPU0     Ready
v4-routing       0/RSP0/CPU0     0/RSP1/CPU0    Not NSR-Ready
central-services 0/RSP0/CPU0     0/RSP1/CPU0     Ready
dlrsc            0/RSP0/CPU0     0/RSP1/CPU0     Ready
dsc              0/RSP0/CPU0     0/RSP1/CPU0     Ready
And now the second "v4-routing" is gone:
Here is what Cisco says about this issue.
Error Message
to partner TCP.
Explanation One or more control messages could not be delivered, after several retries, to the partner
TCP stack. This can leave the TCP stacks in a state that prevents NSR from being restored.
Recommended Action This may be due to a very basic problem with the communications
infrastructure between the TCP stacks running on different nodes. Please collect the following
information and restart the standby TCP process.
One question.
If I am using 4.3.0, do I have to install and activate the SMUs?
e.g.
asr9k-p-4.1.2.CSCty67156.pie
asr9k-p-4.0.1.CSCto05713.pie
or is this already covered in 4.3.0?
I am asking this because I got this SMUs in the 4.3.0 TAR archive.
Hello Smailmilak,
I shouldn't be able to install SMUs from different versions. My scenario is built with two ASR9001 with nV, but i don't think both RSP are synchronizing, since when i cut the power to one node i get lost ~40 seconds of traffic, which is unacceptable.
Do you know the name of the "standby TCP process" called so I can restart it?
I have the problem again.
In which version are you seeing this?
I have seen this sporadically in between a few releases.
When NSR is enabled, it is actually the standby RSP that injects the TCP packets for BGP. (this in order to keep sync on seq numbers)
When the standby is not capable or responding to it, the active will do it himself, but that breaks NSR temporarily.
When you have cluster, the standby RSP is in the rack1 (assuming Rack 0 is the active/primary).
What I Am suspecting is that you may have excessive latency on your EOBC links of cluster?
If that is all not the case, then I would recommend collecting a show tech tcp and opening a TAC case,
regards!
xander
In version 4.3.0.
I don't know the needed commands to check eobc, I am checking some guides right now.
And I have to add the this ASR failed this morning and it had to be reloaded in order to get it to work.
ICMP to directly connected interfaces was not working.
These are the error messages from yesterday.
RP/0/RSP0/CPU0:Mar 18 07:52:38.026 : tcp[426]: %IP-TCP_NSR-3-OUT_OF_SYNC : One or more NSR control messages could not be delivered to partner TCP.
RP/0/RSP0/CPU0:Mar 18 07:52:57.008 : tcp[426]: %IP-TCP_NSR-3-OUT_OF_SYNC : One or more NSR control messages could not be delivered to partner TCP.
RP/0/RSP0/CPU0:Mar 18 07:53:07.007 : tcp[426]: %IP-TCP_NSR-3-OUT_OF_SYNC : One or more NSR control messages could not be delivered to partner TCP.
RP/0/RSP0/CPU0:ASR9010_PE_1#sh redundancy
Mon Mar 18 09:58:02.032 GMT
Redundancy information for node 0/RSP0/CPU0:
Node 0/RSP0/CPU0 is in ACTIVE role
Node Redundancy Partner (0/RSP1/CPU0) is in STANDBY role
Standby node in 0/RSP1/CPU0 is ready
Standby node in 0/RSP1/CPU0 is NSR-ready
Node 0/RSP0/CPU0 is in process group PRIMARY role
Process Redundancy Partner (0/RSP1/CPU0) is in BACKUP role
Backup node in 0/RSP1/CPU0 is ready
Backup node in 0/RSP1/CPU0 is not NSR-ready
Group            Primary         Backup          Status
Process Group Details
Current primary rmf state: Ready
All backup not-ready bits clear - backup should be ready
Current primary rmf state for NSR: Not Ready
                      Reason for backup not NSR-ready
   1011  0/RSP0/CPU0         ospf   v4-routing No connection to standby
        Not ready set Sat Mar  9 04:59:58 2013: 1 week, 2 days, 4 hours, 58 minutes ago
   1044  0/RSP0/CPU0     mpls_ldp   v4-routing LDP NSR sessions not synchronized
        Not ready set Sat Mar  9 05:00:21 2013: 1 week, 2 days, 4 hours, 57 minutes ago
   1012  0/RSP0/CPU0         ospf   v4-routing No connection to standby
        Not ready set Sat Mar  9 05:02:46 2013: 1 week, 2 days, 4 hours, 55 minutes ago
   1049  0/RSP0/CPU0          bgp   v4-routing BGP NSR sessions not synchronized : inst_name=default, inst_id=0
        Not ready set Sat Mar  9 05:03:33 2013: 1 week, 2 days, 4 hours, 54 minutes ago
   1128  0/RSP0/CPU0    l2vpn_mgr   v4-routing L2VPN ATOM sessions not synchronized
        Not ready set Fri Mar 15 15:33:42 2013: 2 days, 18 hours, 24 minutes ago
Reload and boot info
A9K-RSP440-TR reloaded Fri Feb  8 11:44:50 2013: 5 weeks, 2 days, 22 hours, 13 minutes ago
Active node booted Fri Feb  8 11:44:50 2013: 5 weeks, 2 days, 22 hours, 13 minutes ago
Standby node boot Fri Feb  8 11:44:53 2013: 5 weeks, 2 days, 22 hours, 13 minutes ago
Standby node last went not ready Fri Feb  8 11:48:34 2013: 5 weeks, 2 days, 22 hours, 9 minutes ago
Standby node last went ready Fri Feb  8 11:48:34 2013: 5 weeks, 2 days, 22 hours, 9 minutes ago
There have been 0 switch-overs since reload
I will open a TAC case for this!
