02-08-2013 09:03 AM
What does "%IP-TCP_NSR-3-OUT_OF_SYNC One or more NSR control messages could not be delivered to partner TCP" message means in a two ASR9001 nV Edge cluster ?
Does it means that there are problems with both RSP TCP stacks sincronization (control-plane) ? How can i confirm that the Cluster is in sync ?
Thanks !
David
02-08-2013 10:26 AM
I had the same problem on 4 ASR-s, but I checked a few minutes ago and now it's gone!!
And show redundancy showed this:
v6-routing 0/RSP0/CPU0 0/RSP1/CPU0 Ready
mcast-routing 0/RSP0/CPU0 0/RSP1/CPU0 Ready
netmgmt 0/RSP0/CPU0 0/RSP1/CPU0 Ready
v4-routing 0/RSP0/CPU0 0/RSP1/CPU0 Ready
v4-routing 0/RSP0/CPU0 0/RSP1/CPU0 Not NSR-Ready
central-services 0/RSP0/CPU0 0/RSP1/CPU0 Ready
dlrsc 0/RSP0/CPU0 0/RSP1/CPU0 Ready
dsc 0/RSP0/CPU0 0/RSP1/CPU0 Ready
And now the second "v4-routing" is gone:
Here is what Cisco says about this issue.
Error Message
to partner TCP.
Explanation One or more control messages could not be delivered, after several retries, to the partner
TCP stack. This can leave the TCP stacks in a state that prevents NSR from being restored.
Recommended Action This may be due to a very basic problem with the communications
infrastructure between the TCP stacks running on different nodes. Please collect the following
information and restart the standby TCP process.
02-08-2013 10:29 AM
One question.
If I am using 4.3.0, do I have to install and activate the SMUs?
e.g.
asr9k-p-4.1.2.CSCty67156.pie
asr9k-p-4.0.1.CSCto05713.pie
or is this already covered in 4.3.0?
I am asking this because I got this SMUs in the 4.3.0 TAR archive.
02-11-2013 02:46 AM
Hello Smailmilak,
I shouldn't be able to install SMUs from different versions. My scenario is built with two ASR9001 with nV, but i don't think both RSP are synchronizing, since when i cut the power to one node i get lost ~40 seconds of traffic, which is unacceptable.
03-18-2013 02:05 AM
Do you know the name of the "standby TCP process" called so I can restart it?
I have the problem again.
03-18-2013 04:15 PM
In which version are you seeing this?
I have seen this sporadically in between a few releases.
When NSR is enabled, it is actually the standby RSP that injects the TCP packets for BGP. (this in order to keep sync on seq numbers)
When the standby is not capable or responding to it, the active will do it himself, but that breaks NSR temporarily.
When you have cluster, the standby RSP is in the rack1 (assuming Rack 0 is the active/primary).
What I Am suspecting is that you may have excessive latency on your EOBC links of cluster?
If that is all not the case, then I would recommend collecting a show tech tcp and opening a TAC case,
regards!
xander
03-19-2013 01:11 AM
In version 4.3.0.
I don't know the needed commands to check eobc, I am checking some guides right now.
And I have to add the this ASR failed this morning and it had to be reloaded in order to get it to work.
ICMP to directly connected interfaces was not working.
These are the error messages from yesterday.
RP/0/RSP0/CPU0:Mar 18 07:52:38.026 : tcp[426]: %IP-TCP_NSR-3-OUT_OF_SYNC : One or more NSR control messages could not be delivered to partner TCP.
RP/0/RSP0/CPU0:Mar 18 07:52:57.008 : tcp[426]: %IP-TCP_NSR-3-OUT_OF_SYNC : One or more NSR control messages could not be delivered to partner TCP.
RP/0/RSP0/CPU0:Mar 18 07:53:07.007 : tcp[426]: %IP-TCP_NSR-3-OUT_OF_SYNC : One or more NSR control messages could not be delivered to partner TCP.
RP/0/RSP0/CPU0:ASR9010_PE_1#sh redundancy
Mon Mar 18 09:58:02.032 GMT
Redundancy information for node 0/RSP0/CPU0:
Node 0/RSP0/CPU0 is in ACTIVE role
Node Redundancy Partner (0/RSP1/CPU0) is in STANDBY role
Standby node in 0/RSP1/CPU0 is ready
Standby node in 0/RSP1/CPU0 is NSR-ready
Node 0/RSP0/CPU0 is in process group PRIMARY role
Process Redundancy Partner (0/RSP1/CPU0) is in BACKUP role
Backup node in 0/RSP1/CPU0 is ready
Backup node in 0/RSP1/CPU0 is not NSR-ready
Group Primary Backup Status
Process Group Details
Current primary rmf state: Ready
All backup not-ready bits clear - backup should be ready
Current primary rmf state for NSR: Not Ready
1011 0/RSP0/CPU0 ospf v4-routing No connection to standby
Not ready set Sat Mar 9 04:59:58 2013: 1 week, 2 days, 4 hours, 58 minutes ago
1044 0/RSP0/CPU0 mpls_ldp v4-routing LDP NSR sessions not synchronized
Not ready set Sat Mar 9 05:00:21 2013: 1 week, 2 days, 4 hours, 57 minutes ago
1012 0/RSP0/CPU0 ospf v4-routing No connection to standby
Not ready set Sat Mar 9 05:02:46 2013: 1 week, 2 days, 4 hours, 55 minutes ago
1049 0/RSP0/CPU0 bgp v4-routing BGP NSR sessions not synchronized : inst_name=default, inst_id=0
Not ready set Sat Mar 9 05:03:33 2013: 1 week, 2 days, 4 hours, 54 minutes ago
1128 0/RSP0/CPU0 l2vpn_mgr v4-routing L2VPN ATOM sessions not synchronized
Not ready set Fri Mar 15 15:33:42 2013: 2 days, 18 hours, 24 minutes ago
Reload and boot info
A9K-RSP440-TR reloaded Fri Feb 8 11:44:50 2013: 5 weeks, 2 days, 22 hours, 13 minutes ago
Active node booted Fri Feb 8 11:44:50 2013: 5 weeks, 2 days, 22 hours, 13 minutes ago
Standby node boot Fri Feb 8 11:44:53 2013: 5 weeks, 2 days, 22 hours, 13 minutes ago
Standby node last went not ready Fri Feb 8 11:48:34 2013: 5 weeks, 2 days, 22 hours, 9 minutes ago
Standby node last went ready Fri Feb 8 11:48:34 2013: 5 weeks, 2 days, 22 hours, 9 minutes ago
There have been 0 switch-overs since reload
I will open a TAC case for this!
