LED alarms ASR 9901 MAJ & LC start / input ok
Hi i have Cisco 9901 and below error led is red please advice how to tshoot or solve
Red led is for MAJ & LC start / input ok
#admin show led
Sun Oct 6 08:42:45.692 UTC
Location LED Name Mode Color
0/0
0/0-Status LED WORKING RED
0/RSP0
0/RSP0-Fail LED WORKING OFF
0/RSP0-Alarm Minor LED WORKING OFF
0/RSP0-Alarm Major LED WORKING RED
0/RSP0-Alarm Critical LED WORKING OFF
0/FT0
0/FT0-Status LED WORKING GREEN
0/FT1
0/FT1-Status LED WORKING GREEN
0/FT2
0/FT2-Status LED WORKING GREEN
0/PT0
0/PT0-PM0-Status WORKING GREEN
0/PT0-PM1-Status WORKING GREEN
6 Replies 6
balaji.bandi
what code running, check this may be bug :
https://bst.cisco.com/quickview/bug/CSCvt97212
BB
thanks for your replay
but what you mean specifically by "what code running,"
and kindly find below
#admin show alarms brief
Sun Oct 6 12:25:24.538 UTC
Active Alarms
Location Severity Group Set time Description
0/0 major fpd_infra 02/03/23 08:20:11 IPU-FPGA: Golden FPGA is below minimum version, Perform force fpd upgrade
0/0 major fpd_infra 02/03/23 08:20:11 IPU-FSBL: Golden FPGA is below minimum version, Perform force fpd upgrade
0/0 major fpd_infra 02/03/23 08:20:11 IPU-Linux: Golden FPGA is below minimum version, Perform force fpd upgrade
show version give you what is the XR code running on the device.
that log show back dated 2023, check show logging
Is the Service effecting the Environment, contact TAC is best option. (if you have contract)
other option as mentioned part of the bug, when you have maintenance window :
Workaround: Reloading the problem RP clears the alarm
BB
Cisco IOS XR Software, Version 7.9.21
ok i will check with the TAC
the router in installations phase so i could reload without MW
could you provide me with the command to Reloading RP
tkarnani
for this alarm.
1st check "show hw-module fpd"
2nd upgrade hw-module location 0/RP0 fpd <name> force
you can put the name listed in the alarm
thanks
