NSC-55A2-MOD-SE-S procedure for IOS XR upgrade
nesttech1
Is there a way to upgrade the IOS on this system using the external USB ?
While the system is booting, it does not show any options to boot from the the USB, so that we can upgrade the IOS XR version
Let me know what is the process to upgrade the IOS XR on this NSC-55A2-MOD-SE-S device
tkarnani
Hi, you can upgrade via usb
however it wont be graceful, it will wipe the routers disk and have it running the new code
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5500/system-setup/75x/b-system-setup-cg-ncs5500-75x/perform-disaster-recovery.html
you will need to prepare the usb, download the usb image, extract to the root of the usb
hit esc or delete depending on the version of the bio and you can boot via usb
tkarnani
Thank you for this link.
We followed this procedure and everything worked perfect.
smilstea
Like Tarun mentioned you can boot off usb to reimage the device. You can also store the regular image on usb and use usb (disk2) as the source for upgrading from the Exec prompt.
Sam
