07-11-2024 02:07 PM
Is there a way to upgrade the IOS on this system using the external USB ?
While the system is booting, it does not show any options to boot from the the USB, so that we can upgrade the IOS XR version
Let me know what is the process to upgrade the IOS XR on this NSC-55A2-MOD-SE-S device
Solved! Go to Solution.
07-11-2024 05:48 PM
Hi, you can upgrade via usb
however it wont be graceful, it will wipe the routers disk and have it running the new code
you will need to prepare the usb, download the usb image, extract to the root of the usb
hit esc or delete depending on the version of the bio and you can boot via usb
07-11-2024 05:48 PM
07-12-2024 04:41 PM
Thank you for this link.
We followed this procedure and everything worked perfect.
07-11-2024 06:16 PM
