05-10-2024 04:14 AM
Hello everyone,
We have the NCS55A1 router. We tried upgrading with ncs5500-goldenk9-x-7.6.2-SPGISO0001.iso from the IOS-XR 7.4.2 version, but the replacement failed with an "Internal error" message. After that failure, we performed the upgrade with NCS5500-iosxr-k9-7.6.2.tar, and then replacement with ncs5500-goldenk9-x-7.6.2-SPGISO0001.iso. The replacement was successful but "admin show install health" displayed high directory usage:
INFO ********************************************************************************
WARNING XR disk space usage is high at node 0/RP0 for default-sdr
WARNING Please check for following usages
WARNING Directory name:/ and usage is: 82
ERROR Clean up the space for above directories
After "install remove inactive all" some packages still persist and can't be removed:
4 inactive package(s) found:
systemd-244.5-r0.xr
ncs5500-spirit-boot-2.0.0.0-r762
sudo-1.8.32-r0.xr
kernel-image-bzimage-5.4.142-yocto-standard-5.4.142+git0+719be4bd6c_108b8b-r0.xr
I have some questions if someone can help.
1. Is it possible to perform the upgrade (replacement) with the GISO version different from the currently running IOS-XR version at all, or the GISO version must match the currently running IOS-XR version?
2. How can we resolve the problem with "ERROR Clean up the space", and how to remove inactive packages? The harddisk: has 18692004 kbytes free.
Any help is appreciated.
Miljan Kostadinovic
05-16-2024 12:45 AM
Hello @miljankostadinovic ,
Hope you are doing well.
Reading your topic -
>>> Yes. From field experience I've performed upgrade with GISO image from 6.6.3 to 7.5.2. In some cases, it's not possible, it depends of the NCS 5500 platform and some SMUs might be needed.
>>> I see you've performed install remove inactive all. I'm wondering if you've performed it from both XR and admin mode.
Please let me know it it helps you.
Have a wonderful day.
Kind Regards,
05-16-2024 02:54 AM
Hello @ANP ,
Thank you for your response. Yes, we tried to remove it in both modes:
sysadmin-vm:0_RP0# show install inactive
Sat Aug 21 05:50:22.170 UTC+00:00
Node 0/RP0 [RP]
Inactive Packages:
sudo-1.8.32-r0.admin
systemd-244.5-r0.host
systemd-244.5-r0.admin
ncs5500-sysadmin-hostos-7.6.2-r762.host
kernel-image-bzimage-5.4.142-yocto-standard-5.4.142+git0+719be4bd6c_108b8b-r0.host
sudo-1.8.32-r0.host
kernel-image-bzimage-5.4.142-yocto-standard-5.4.142+git0+719be4bd6c_108b8b-r0.admin
ncs5500-sysadmin-hostos-7.6.2-r762.admin
sysadmin-vm:0_RP0#
sysadmin-vm:0_RP0# install remove inactive
Sat Aug 21 05:50:30.925 UTC+00:00
result Sat Aug 21 05:50:32 2021 Install operation 15 (install remove) started by user 'root' will continue asynchronously.
sysadmin-vm:0_RP0# Sat Aug 21 05:50:40 2021 Install operation 15 completed successfully.
sysadmin-vm:0_RP0#
Sat Aug 21 05:50:48.893 UTC+00:00
Node 0/RP0 [RP]
Inactive Packages:
sudo-1.8.32-r0.host
sysadmin-vm:0_RP0#
RP/0/RP0/CPU0:ncs55a1#sh install inactive
Sat Aug 21 05:48:55.223 UTC
systemd-244.5-r0.xr
sudo-1.8.32-r0.xr
RP/0/RP0/CPU0:ncs55a1#install remove inactive sync
Sat Aug 21 05:49:12.861 UTC
2021-08-21 05:49:14 Install operation 2762 started by root:
install remove inactive synchronous
2021-08-21 05:49:16 Action 1: install remove action started
2021-08-21 05:49:16 Package list:
2021-08-21 05:49:16 systemd-244.5-r0.xr.x86_64
2021-08-21 05:49:16 ncs5500-spirit-boot-2.0.0.0-r762.x86_64
2021-08-21 05:49:16 sudo-1.8.32-r0.xr.x86_64
2021-08-21 05:49:17 kernel-image-bzimage-5.4.142-yocto-standard-5.4.142+git0+719be4bd6c_108b8b-r0.xr.x86_64
2021-08-21 05:49:19 Following packages are skipped:
2021-08-21 05:49:19 systemd-244.5-r0.xr.x86_64
2021-08-21 05:49:19 ncs5500-spirit-boot-2.0.0.0-r762.x86_64
2021-08-21 05:49:19 sudo-1.8.32-r0.xr.x86_64
2021-08-21 05:49:19 kernel-image-bzimage-5.4.142-yocto-standard-5.4.142+git0+719be4bd6c_108b8b-r0.xr.x86_64
2021-08-21 05:49:19 Action 1: install remove action completed successfully
2021-08-21 05:49:21 Install operation 2762 finished successfully
2021-08-21 05:49:21 Ending operation 2762
Sat Aug 21 05:49:32.380 UTC
systemd-244.5-r0.xr
sudo-1.8.32-r0.xr
So, in both modes, the "show install health" show the same:
INFO Total time taken: 7.63650202751 seconds.
sysadmin-vm:0_RP0#
I'm wondering if there is another way to free-up the space and solve the problem.
