04-27-2020 06:10 AM
hello Experties
We have ASR9k10 with single RSP440 installed as active the plane to upgrade it to RSP880
after shutting down the device the replace it with single RSP880 and booting up it got only rebooting again and again
copy of what showing in console while booting is attached. so what's the issue?
another question dose the RSP880 ususally come reloaded with IOS XR image or i have to install it myself
thanks
04-27-2020 06:16 AM - edited 04-27-2020 06:21 AM
Have you changed the link speed to 10G? Step 14
i am unsure if this is the LT version of the RSP880, then the steps are slightly different, if it is we may have to change
rommon 1 > RSP_LINK_1G=1 rommon 2 > ALDRIN_VERSION_DISABLE=1 rommon 3 > RSP4L_ALDRIN_1G=1 rommon 4 > sync
Step 8
04-27-2020 06:27 AM
04-27-2020 06:39 AM - edited 04-27-2020 06:42 AM
Hi Ahmed,
The original RSP440, can have any code above 5.3.1, 5.3.1 is just the first code to support RSP880.
so either we can try to sync to the original RSP440 or use Turbo boot to load the code on the RSP880
if the RSP880 does not have an image. instead it looks like its failing to sync. so we can try to load an image via turboboot.
you can download 6.x code and try to load it via USB
