04-17-2019 01:28 AM
Dear Support,
We upgrading IOSxr 64 bit 6.3.2 to 6.5.3.
We can not upgrade as the rootfs: has not enough free space.
As a workaround we removed some unecessary packages. (on an other router we had to remove necessary package as well)
After the upgrade we could add the packages again. (only the kernel (ISO) required the space)
It does not occure with other IOS XRs, neither during downgrade.
Is this issue related to 6.3.2 eXR?
It makes the upgrade a bit cumbersome...
Do you have other methode to overcome this issue?
04-17-2019 05:56 AM
can we check the filesystem to see where the space is used?
from xr vm
show media run df from admin
show install repository all
show media run df /misc/disk1 run df -kh
04-25-2019 06:54 AM
04-25-2019 07:10 AM
04-18-2019 08:57 PM
04-25-2019 06:50 AM
It is in the attachement, I belive.
Imre
04-18-2019 09:02 PM
I see pretty much all packages in show install active. So just removing 3 packages unblocked you from install ?
What was there in show install inactive?
04-25-2019 06:48 AM
RP/0/RSP0/CPU0:bng3#sh install inactive
Thu Apr 4 15:19:25.234 CEST 16 inactive package(s) found:
asr9k-mini-x64-6.5.3
asr9k-xr-6.5.3
asr9k-li-x64-1.1.0.0-r653
asr9k-mpls-x64-2.0.0.0-r653
asr9k-9000v-nV-x64-1.0.0.0-r632
asr9k-eigrp-x64-1.0.0.0-r632
asr9k-k9sec-x64-2.1.0.0-r653
asr9k-optic-x64-1.0.0.0-r653
asr9k-m2m-x64-2.0.0.0-r653
asr9k-mcast-x64-2.0.0.0-r632
asr9k-mgbl-x64-2.0.0.0-r653
asr9k-bng-x64-1.0.0.0-r653
asr9k-mcast-x64-2.0.0.0-r653
asr9k-isis-x64-1.1.0.0-r653
asr9k-mpls-te-rsvp-x64-2.1.0.0-r653
asr9k-ospf-x64-1.0.0.0-r632
04-25-2019 07:21 AM
Can we remove the inactive packages and try upgrading?
install remove inactive all
04-25-2019 07:28 AM
