Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Hi,I have SIP Device, but I can't see the Address in the JTAPI Test Tool,I don't know whether beacuse of "Device is not trusted" this causes?The CUCM configuration:3rd SIP PhonesDirectory NumberEnd UserJTAPI Test ToolThanks in advance
lggang001 by Community Member
  • 859 Views
  • 1 replies
I have a client that has some wireless phones with Jabber client.  I have an application similar to this:  Our audio stations are located throughout the store.  A customer can push a button on the audio station and that will trigger a message to the ...
deanbostic by Community Member
  • 541 Views
  • 1 replies
My application attempts to call an extension from a CTI port. The call to lineMakeCall() is successful but I immediately get back a disconnect event with reason LINEDISCONNECTMODE_BADADDRESS. My function call looks like this:int nResult = lineMakeCal...
bhoover02 by Level 3
  • 882 Views
  • 1 replies
Hi Support,I have found pieces of information about this, but i am at the point where i need to ping you for an answer or for the link to the correct doc. However, i would much prefer if someone could clearly explain here...I have wrote an Applicatio...
Hi Support,Is there a limit to the number of devices a single TAPI application (using a single TSP) can receive Call Events for? I have completed an Application where i enumerate (open and monitor) all the Line devices assigned to my user in CUCM and...
Dear, I am using Cisco JTAPI to monitor extensions in Cisco UCM.I found strange bbehaviorof JTAPI while dialing from JTAPI monitored device.The call pattern must be like Offered->Dialling->Answered->Disconnected.Instead I am getting call events like ...
Dear All,I am not sure about this is correct forum for this query.All of us know that CTIManager sends information about CTI events.I want to change behavior of CTIManager so that CTIManager can send information about particular events only.Can we do...
Hi I have the scenario :1> User A , B and C ... etc are in conference call through cti terminal 2> User A makes call to external user say it as User D , this call should be a private call between User A and User D , 3> Once User D ready to join confe...
shahhuss by Community Member
  • 624 Views
  • 1 replies
In my TAPI application with CUCM 7.0.1 I need to place a call from some "virtual" extension that isn't associated with any actual phone to an actual extension, play a recording, and listen for DTMF. In other TAPI applications I have written I have us...
  • 1736 Views
  • 2 replies
