CUBE One-Way Audio
3MAD
Dears, hope you all doing well,
We have this environment (call flow):
ITSP (SIP Trunk) --> CUBE --> CUCM (5001 is AA) --> CUC (Customer Service 0 is a hunt group on CUCM extension number 1888)
We have one way-audio and the call will disconnect after 10-15 seconds when calling to this hunt-group, the weird thing is when I do a "debug ccsip messages" the call will work fine
This is the running config on my CUBE
voice-card 0
 dspfarm
 dsp services dspfarm
voice rtp send-recv
voice service voip
 ip address trusted list
  ipv4 172.25.227.29 255.255.255.255
  ipv4 10.141.40.233 255.255.255.255
  ipv4 10.170.16.69 255.255.255.255
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 signaling forward unconditional
 fax protocol pass-through g711alaw
 sip
  early-offer forced
  no call service stop
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
 codec preference 4 g729br8
voice class dualtone-detect-params 1
 freq-max-power 0
 freq-min-power 13
 freq-power-twist 4
 cadence-variation 8
voice class e164-pattern-map 1
 description ##ALL INCOMING NUMBERS FROM STC##
  e164 ^01142087..
  e164 ^42087..
voice class e164-pattern-map 2
 description ##INCOMING NUMBERS FROM CUCM##
  e164 ^01142087..
  e164 ^42087..
voice class server-group 1
 ipv4 172.25.227.29 preference 1
 description ##CUCM##
voice translation-rule 2
 rule 1 /^.*/ /5001/
voice translation-rule 4
 rule 1 /^9/ //
voice translation-profile IN-FROM-STC
translate called 2
voice translation-profile OUT-TO-STC
translate called 4
interface GigabitEthernet0/0
 description ## LAN ##
 ip address 172.25.227.126 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 description ## STC_SIP_CIRCUIT ##
 ip address 10.170.16.70 255.255.255.252
 duplex auto
 speed auto
no ip http server
no ip http secure-server
ip route 10.141.40.233 255.255.255.255 10.170.16.69
ip ssh version 2
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dspfarm profile 1 transcode universal
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 codec g722-64
 maximum sessions 10
 associate application CUBE
dial-peer voice 1 voip
 description ##ALL INCOMING NUMBERS FROM ITSP##
 translation-profile incoming IN-FROM-STC
 session protocol sipv2
 session target ipv4:172.25.227.29
 session transport udp
 incoming called e164-pattern-map 1
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/2
 voice-class sip bind media source-interface GigabitEthernet0/2
 dtmf-relay rtp-nte sip-kpml
 no fax-relay sg3-to-g3
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 no vad
dial-peer voice 2 voip
 description ##TO CUCM##
 destination-pattern 5001
 session server-group 1
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/0
 voice-class sip bind media source-interface GigabitEthernet0/0
 fax-relay ecm disable
 no vad
dial-peer voice 3 voip
 description ##ALL INCOMING NUMBERS FROM CUCM##
 incoming calling e164-pattern-map 2
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 4 voip
 description ## OUTGOING CALL TO ITSP##
 translation-profile outgoing OUT-TO-STC
 destination-pattern 9T
 session target ipv4:10.141.40.233
 voice-class codec 1 offer-all
 voice-class sip early-offer forced
 dtmf-relay rtp-nte cisco-rtp h245-alphanumeric h245-signal sip-kpml sip-notify
 no vad
Thanks in advance
In general your dial peer configuration is a little bit messy. One thing that sticks out is that you have the IP for the CUCM as the destination on your inbound dial peer from the ITSP. This must be a mistake I assume. I would make these changes to your configuration.
ip route 0.0.0.0 0.0.0.0 172.25.227.xxx !set this to the gateway for your internal network.
voice class uri 1 sip
host ipv4:10.141.40.233
voice class uri 2 sip
host ipv4:172.25.227.29
incoming uri via 1
voice-class codec 1
dtmf-relay rtp-nte cisco-rtp sip-kpml sip-notify
no vad
dial-peer voice 10 voip
no vad
incoming uri via 2
voice-class codec 1
no vad
dial-peer voice 20 voip
voice-class codec 1
no vad
Keeping uneven number starting dial peers as used for ITSP and even numbered used by CUCM will help you quickly see the call flow moving forward. In my example single number means it's an inbound dial peer and double numbers means it's an outbound dial peer. Purely cosmetics, but does help to identify things more easily.
You should also verify what port range your ITSP uses for RTP. As you have not defined it in configuration it will use the default and that might not work for your ITSP. What kind of router do you use? If it's a ISR4K the default RTP port range is 8000-48198. You can see this by running this command "sh voip rtp connections" when you have an ongoing call. The output would be similar to this.
VoIP RTP Port Usage Information:
Max Ports Available: 19999, Ports Reserved: 101, Ports in Use: 2
Port range not configured
Min Max Ports Ports Ports
Media-Address Range Port Port Available Reserved In-use
Global Media Pool 8000 48198 19999 101 2
VoIP RTP active connections :
No. CallId dstCallId LocalRTP RmtRTP LocalIP RemoteIP MPSS VRF
1 2908314 2908315 40098 61704 10.119.217.246 84.241.227.55 NO NA
2 2908315 2908314 40102 24578 10.82.62.10 10.64.122.49 NO
// Notice the min and max port range in the above output. You will see it is 8000-48198.
Response Signature
16 Replies 16
3MAD
I was able to regenerate the issue and did a debug
Spoiler
SIP Call messages tracing is enabled
VGW01#
*Apr 30 10:29:24.115: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:560032888@172.25.227.126:5060 SIP/2.0
Via: SIP/2.0/UDP 172.25.227.29:5060;branch=z9hG4bK3fecbacaff7
From: <sip:5001@172.25.227.29>;tag=254760~1bfdf346-5239-45d3-85f0-26020bcb99c6-26328730
To: <sip:560032888@172.25.227.126>;tag=3419A6C8-1CB7
Date: Thu, 30 Apr 2020 10:42:51 GMT
Call-ID: 42FD8F2E-8A0411EA-B074B4DA-CB90D725@172.25.227.126
Supported: timer,resource-priority,replaces
Cisco-Guid: 1123833413-2315522538-2960045274-3415267109
User-Agent: Cisco-CUCM11.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Allow-Events: presence
Session-ID: 01f970f9d4f467343ab7030eab254761;remote=d41e0b8235b74f8a2d1449a2ab254760
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=MIXED
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-Expires: 1800;refresher=uac
Min-SE: 1800
P-Preferred-Identity: <sip:5000@172.25.227.29>
Remote-Party-ID: <sip:5000@172.25.227.29>;party=calling;screen=no;privacy=off
Contact: <sip:5001@172.25.227.29:5060>;automata
Content-Type: application/sdp
Content-Length: 245
v=0
o=CiscoSystemsCCM-SIP 254760 2 IN IP4 172.25.227.29
s=SIP Call
c=IN IP4 0.0.0.0
b=TIAS:64000
b=AS:64
t=0 0
m=audio 21298 RTP/AVP 0 101
a=ptime:20
a=rtpmap:0 PCMU/8000
a=inactive
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
*Apr 30 10:29:24.123: //58974/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 30 Apr 2020 10:29:24 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.5.3.M
Content-Length: 0
*Apr 30 10:29:24.123: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:560032888@10.141.40.233:5060;user=phone;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.170.16.70:5060;branch=z9hG4bKD372626
Remote-Party-ID: <sip:5000@10.170.16.70>;party=calling;screen=no;privacy=off
From: <sip:4208730@10.170.16.70;user=phone>;tag=3419A6E4-945
To: <sip:560032888@10.141.40.233;user=phone>;tag=fsf2fb2e-CC-35
Call-ID: kbttbpus2csedashoupddud4hbbs2obk@SoftX3000
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
User-Agent: Cisco-SIPGateway/IOS-15.5.3.M
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1588242564
Contact: <sip:4208730@10.170.16.70:5060>
Expires: 180
Content-Length: 259
v=0
o=CiscoSystemsSIP-GW-UserAgent 5869 9015 IN IP4 10.170.16.70
s=SIP Call
c=IN IP4 10.170.16.70
t=0 0
m=audio 18544 RTP/AVP 0 116
a=rtpmap:116 telephone-event/8000
a=fmtp:116 0-15
a=ptime:20
a=inactive
*Apr 30 10:29:24.271: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Contact: <sip:560032888@10.141.40.233:5060;user=phone;transport=udp>
Content-Length: 217
v=0
o=HuaweiSoftX3000 276661 276662 IN IP4 10.141.40.233
s=Sip Call
c=IN IP4 10.141.40.233
t=0 0
m=audio 57106 RTP/AVP 0 116
a=fmtp:116 0-15
a=inactive
*Apr 30 10:29:24.275: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:560032888@10.141.40.233:5060;user=phone;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.170.16.70:5060;branch=z9hG4bKD38740
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Apr 30 10:29:24.279: //58974/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Remote-Party-ID: <sip:560032888@172.25.227.126>;party=called;screen=no;privacy=off
Contact: <sip:560032888@172.25.227.126:5060>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 265
v=0
o=CiscoSystemsSIP-GW-UserAgent 4894 1461 IN IP4 172.25.227.126
s=SIP Call
c=IN IP4 172.25.227.126
t=0 0
m=audio 18546 RTP/AVP 0 101
a=inactive
a=fmtp:101 0-15
a=ptime:20
*Apr 30 10:29:24.279: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:560032888@172.25.227.126:5060 SIP/2.0
Via: SIP/2.0/UDP 172.25.227.29:5060;branch=z9hG4bK3fed64ef8f9d
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Apr 30 10:29:24.339: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:560032888@172.25.227.126:5060 SIP/2.0
Via: SIP/2.0/UDP 172.25.227.29:5060;branch=z9hG4bK3fef40fb7eaf
Max-Forwards: 70
CSeq: 102 UPDATE
Session-ID: 00000000000000000000000000000000;remote=d41e0b8235b74f8a2d1449a2ab254760
Min-SE: 1800
P-Asserted-Identity: "Customer Support" <sip:1888@172.25.227.29>
Remote-Party-ID: "Customer Support" <sip:1888@172.25.227.29>;party=calling;screen=yes;privacy=off
Content-Length: 0
*Apr 30 10:29:24.339: //58974/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 UPDATE
Require: timer
Supported: timer
Content-Length: 0
*Apr 30 10:29:24.343: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:4208730@10.170.16.70:5060 SIP/2.0
Via: SIP/2.0/UDP 10.141.40.233:5060;branch=z9hG4bK1c7de910agpsrin30er0ch0000020.1
From: <sip:560032888@10.141.40.233;user=phone>;tag=fsf2fb2e-CC-35
To: <sip:4208730@10.170.16.70;user=phone>;tag=3419A6E4-945
CSeq: 4 OPTIONS
Accept: application/sdp
Max-Forwards: 69
Content-Length: 0
*Apr 30 10:29:24.343: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
UPDATE sip:560032888@10.141.40.233:5060;user=phone;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.170.16.70:5060;branch=z9hG4bKD3965F
Max-Forwards: 70
Supported: timer,resource-priority,replaces,sdp-anat
CSeq: 102 UPDATE
Min-SE: 1800
Remote-Party-ID: "Customer Support" <sip:1888@10.170.16.70>;party=called;screen=yes;privacy=off
Content-Length: 0
*Apr 30 10:29:24.347: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.25.227.29:5060;branch=z9hG4bK3ff738094728
CSeq: 103 INVITE
Max-Forwards: 70
Expires: 180
Min-SE: 1800
Content-Length: 0
*Apr 30 10:29:24.347: //58974/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 103 INVITE
Content-Length: 0
*Apr 30 10:29:24.395: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 UPDATE
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 4 OPTIONS
Content-Length: 468
v=0
s=SIP Call
t=0 0
a=fmtp:116 0-15
a=ptime:20
a=inactive
m=image 18544 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Sent:
Via: SIP/2.0/UDP 10.170.16.70:5060;branch=z9hG4bKD3A17F
Remote-Party-ID: "Customer Support" <sip:1888@10.170.16.70>;party=calling;screen=yes;privacy=off
Min-S
VGW01#E: 1800
CSeq: 103 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
*Apr 30 10:29:24.475: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 INVITE
Content-Length: 205
v=0
o=HuaweiSoftX3000 276661 276663 IN IP4 10.141.40.233
s=Sip Call
t=0 0
a=fmtp:116 0-15
*Apr 30 10:29:24.479: //58974/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 325
v=0
o=CiscoSystemsSIP-GW-UserAgent 4894 1462 IN IP4 172.25.227.126
s=SIP Call
t=0 0
m=audio 18546 RTP/AVP 0 8 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=fmtp:101 0-15
a=ptime:20
*Apr 30 10:29:24.495: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.25.227.29:5060;branch=z9hG4bK3ff85942f57a
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 182
v=0
o=CiscoSystemsCCM-SIP 254760 4 IN IP4 172.25.227.29
s=SIP Call
c=IN IP4 172.25.227.29
t=0 0
m=audio 25006 RTP/AVP 0
a=X-cisco-media:umoh
a=ptime:20
*Apr 30 10:29:24.503: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.170.16.70:5060;branch=z9hG4bKD3BB27
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 5869 9016 IN IP4 10.170.16.70
s=SIP Call
t=0 0
a=fmtp:116 0-16
a=ptime:20
*Apr 30 10:29:24.559: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.141.40.233:5060;branch=z9hG4bK1c7de910agpsrin30er0ch0000g20.1
CSeq: 5 OPTIONS
Max-Forwards: 69
Content-Length: 0
*Apr 30 10:29:24.559: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 5 OPTIONS
Accept: ap
VGW01#plication/sdp
Content-Length: 456
v=0
s=SIP Call
t=0 0
a=fmtp:116 0-16
a=ptime:20
a=T38FaxVersion:0
VGW01#
*Apr 30 10:29:27.227: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.25.227.29:5060;branch=z9hG4bK3ff970620117
Date: Thu, 30 Apr 2020 10:42:54 GMT
CSeq: 104 INVITE
Max-Forwards: 70
Expires: 180
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Min-SE: 1800
Content-Length: 188
v=0
o=CiscoSystemsCCM-SIP 254760 5 IN IP4 172.25.227.29
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
a=ptime:20
a=inactive
*Apr 30 10:29:27.231: //58974/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 30 Apr 2020 10:29:27 GMT
CSeq: 104 INVITE
Content-Length: 0
*Apr 30 10:29:27.231: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.170.16.70:5060;branch=z9hG4bKD3C26AE
Min-SE: 1800
CSeq: 104 INVITE
Max-Forwards: 70
Timestamp: 1588242567
Expires: 180
Content-Length: 331
v=0
o=CiscoSystemsSIP-GW-UserAgent 5869 9017 IN IP4 10.170.16.70
s=SIP Call
t=0 0
m=audio 18544 RTP/AVP 0 8 18 116
a=fmtp:116 0-16
a=ptime:20
a=inactive
*Apr 30 10:29:27.391: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 104 INVITE
Content-Length: 217
v=0
o=HuaweiSoftX3000 276661 276664 IN IP4 10.141.40.233
s=Sip Call
t=0 0
a=fmtp:116 0-15
a=inactive
*Apr 30 10:29:27.399: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.170.16.70:5060;branch=z9hG4bKD3D2154
Max-Forwards: 70
CSeq: 104 ACK
Content-Length: 0
*Apr 30 10:29:27.399: //58974/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 104 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 209
v=0
o=CiscoSystemsSIP-GW-UserAgent 4894 1463 IN IP4 172.25.227.126
s=SIP Call
t=0 0
a=inactive
a=ptime:20
*Apr 30 10:29:27.399: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.25.227.29:5060;branch=z9hG4bK3ffbe7e94e
Max-Forwards: 70
CSeq: 104 ACK
Content-Length: 0
*Apr 30 10:29:27.403: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.25.227.29:5060;branch=z9hG4bK3ffc4d732955
CSeq: 105 INVITE
Max-Forwards: 70
Expires: 180
Min-SE: 1800
Contact: <sip:5001@172.25.227.29:5060>;video;audio;automata
Content-Length: 0
*Apr 30 10:29:27.403: //58974/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 105 INVITE
Content-Length: 0
*Apr 30 10:29:27.403: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.170.16.70:5060;branch=z9hG4bKD3EA2F
Min-SE: 1800
CSeq: 105 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
*Apr 30 10:29:27.459: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
VGW01#OPTIONS sip:4208730@10.170.16.70:5060 SIP/2.0
Via: SIP/2.0/UDP 10.141.40.233:5060;branch=z9hG4bK1c7de910agpsrin30er0ch0000030.1
CSeq: 6 OPTIONS
Max-Forwards: 69
Content-Length: 0
*Apr 30 10:29:27.467: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 105 INVITE
Content-Length: 205
v=0
o=HuaweiSoftX3000 276661 276665 IN IP4 10.141.40.233
s=Sip Call
t=0 0
a=fmtp:116 0-15
*Apr 30 10:29:27.959: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 6 OPTIONS
Max-Forwards: 69
Content-Length: 0
*Apr 30 10:29:27.959: %SIP-3-BADPAIR: Unexpected event 38 (SIPSPI_EV_CC_OPTIONS_RESP) in state 25 (SIP_STATE_MIDCALL_RECD_SUCCESS) substate 0 (SUBSTATE_NONE)
*Apr 30 10:29:28.059: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 105 INVITE
Content-Length: 205
v=0
s=Sip Call
VGW01#
t=0 0
a=fmtp:116 0-15
*Apr 30 10:29:28.995: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 105 INVITE
Content-Length: 205
v=0
s=Sip Call
t=0 0
a=fmtp:116 0-15
*Apr 30 10:29:28.995: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 6 OPTIONS
Max-Forwards: 69
Content-Length: 0
VGW01#
*Apr 30 10:29:28.995: %SIP-3-BADPAIR: Unexpected event 38 (SIPSPI_EV_CC_OPTIONS_RESP) in state 25 (SIP_STATE_MIDCALL_RECD_SUCCESS) substate 0 (SUBSTATE_NONE)
VGW01#
*Apr 30 10:29:30.955: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 105 INVITE
Content-Length: 205
v=0
s=Sip Call
t=0 0
a=fmtp:116 0-15
*Apr 30 10:29:31.279: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 6 OPTIONS
Max-Forwards: 69
Content-Length: 0
VGW01#
*Apr 30 10:29:31.279: %SIP-3-BADPAIR: Unexpected event 38 (SIPSPI_EV_CC_OPTIONS_RESP) in state 25 (SIP_STATE_MIDCALL_RECD_SUCCESS) substate 0 (SUBSTATE_NONE)
VGW01#
*Apr 30 10:29:32.963: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.170.16.70:5060 SIP/2.0
Via: SIP/2.0/UDP 10.141.40.233:5060;branch=z9hG4bKug0vg100909ft5fp5580.1
Call-ID: tpstho2ufp7tueac7uhhu2ptkpaocfd2@SoftX3000
To: <sip:10.170.16.70>
CSeq: 1 OPTIONS
Max-Forwards: 69
Content-Length: 0
*Apr 30 10:29:32.967: //58976/50E17680B076/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.170.16.70>;tag=341A01D0-153A
Date: Thu, 30 Apr 2020 10:29:32 GMT
CSeq: 1 OPTIONS
VGW01#riority,replaces,sdp-anat
Content-Length: 167
v=0
o=CiscoSystemsSIP-GW-UserAgent 8173 6454 IN IP4 10.170.16.70
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
VGW01#
*Apr 30 10:29:34.951: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 105 INVITE
Content-Length: 205
v=0
s=Sip Call
t=0 0
a=fmtp:116 0-15
*Apr 30 10:29:35.459: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 6 OPTIONS
Max-Forwards: 69
Content-Length: 0
VGW01#
*Apr 30 10:29:35.463: %SIP-3-BADPAIR: Unexpected event 38 (SIPSPI_EV_CC_OPTIONS_RESP) in state 25 (SIP_STATE_MIDCALL_RECD_SUCCESS) substate 0 (SUBSTATE_NONE)
VGW01#
*Apr 30 10:29:38.951: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 105 INVITE
Content-Length: 205
v=0
s=Sip Call
t=0 0
a=fmtp:116 0-15
*Apr 30 10:29:39.423: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:560032888@172.25.227.126:5060 SIP/2.0
Via: SIP/2.0/UDP 172.25.227.29:5060;branch=z9hG4bK3ffe5389f344
Max-Forwards: 70
CSeq: 106 BYE
Reason: Q.850;cause=47
Session-ID: 1972727b00105000a00000af1fc0d69e;remote=d41e0b8235b74f8a2d1449a2ab254760
Content-Length: 0
*Apr 30 10:29:39.427: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:560032888@10.141.40.233:5060;user=phone;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.170.16.70:5060;branch=z9hG4bKD3F1719
Date: Thu, 30 Apr 2020 10:29:35 GMT
Max-Forwards: 70
Timestamp: 1588242579
CSeq: 106 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=782,OS=124166,PR=830,OR=129524,PL=0,JI=0,LA=0,DU=29
Content-Length: 0
*Apr 30 10:29:39.427: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
VGW01#SIP/2.0 200 OK
Date: Thu, 30 Apr 2020 10:29:39 GMT
CSeq: 106 BYE
P-RTP-Stat: PS=830,OS=129524,PR=782,OR=124166,PL=0,JI=0,LA=0,DU=29
Content-Length: 0
*Apr 30 10:29:39.479: //58973/42FC5645B06E/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 106 BYE
Content-Length: 0
VGW01#
*Apr 30 10:29:42.951: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 6 OPTIONS
Max-Forwards: 69
Content-Length: 0
*Apr 30 10:29:42.955: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
VGW01#SIP/2.0 481 Call Leg/Transaction Does Not Exist
Date: Thu, 30 Apr 2020 10:29:42 GMT
CSeq: 6 OPTIONS
Content-Length: 0
VGW01#
*Apr 30 10:29:53.027: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.141.40.233:5060;branch=z9hG4bKme71is30a04732bf5en0.1
Call-ID: escds72csdfa7psauhcpcp2cboufhhe2@SoftX3000
CSeq: 1 OPTIONS
Max-Forwards: 69
Content-Length: 0
*Apr 30 10:29:53.027: //58977/5CD662A7B078/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.170.16.70>;tag=341A502C-C64
Date: Thu, 30 Apr 2020 10:29:53 GMT
CSeq: 1 OPTIONS
VGW01#iority,replaces,sdp-anat
Content-Length: 167
v=0
o=CiscoSystemsSIP-GW-UserAgent 6982 2523 IN IP4 10.170.16.70
s=SIP Call
t=0 0
VGW01#
*Apr 30 10:30:01.343: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:172.25.227.126:5060 SIP/2.0
Via: SIP/2.0/TCP 172.25.227.29:5060;branch=z9hG4bK40054a2054c0
To: <sip:172.25.227.126>
Date: Thu, 30 Apr 2020 10:43:28 GMT
Call-ID: 6bcb0d80-eaa1abd0-3954-1de319ac@172.25.227.29
CSeq: 101 OPTIONS
Contact: <sip:172.25.227.29:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
Sent:
SIP/2.0 200 OK
To: <sip:172.25.227.126>;tag=341A70A8-DC9
Date: Thu, 30 Apr 2020 10:30:01 GMT
CSeq: 101 OPTIONS
VGW01#replaces,sdp-anat
Content-Length: 173
v=0
o=CiscoSystemsSIP-GW-UserAgent 9194 5508 IN IP4 172.25.227.126
s=SIP Call
t=0 0
VGW01#u all
All possible debugging has been turned off
VGW01#
Hi 3MAD,
Sorry I couldn't help in your previous post.
In your debug there is a message that stands out right before the call is disconnected:
VGW01#
VGW01#
Received:
SIP/2.0 200 OK
To be honest I am not sure if this is normal with your ITSP but it is worth checking if other working calls show the same message. If it is not the case, I would check if you are hitting the following bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf97230/?rfs=iqvred
Good Luck
Hi Amine,
No issues, thanks for your reply :)
I tried creating "voice class sip-profiles 14" from the link you provided and there's no difference in the results, the weird thing is that when we do a "debug ccsip messages" the issue will be resolved until I stop the debug or log-off the router.
Today I had an email from our ITSP, kindly check it also
Dear Emad,
Please check our analysis regarding your call forwarding scenario as per our live test :
Calling # 0506251016
Called # 011-4208730
INVITE message send to you with Calling # 0506251016 & Called # 011-4208730 from our SX HuaweiSoftx3000 Figure “1”.
Re-Invite send with Calling # 011-4208730 & Called # 0506251016 from your Cisco device “as call forwarding” Figure “2”.
UPDATE message with Calling # 011-4208730 & Called # 0506251016 and “Remote-Party-ID: "Customer Support" <sip:1888@10.170.16.70” Figure “3”.
Conclusion:-
The call is forwarded to same calling number which means there is no call forwarding to employees mobile numbers.
Need to add employees mobile numbers which need to forward the call to it in TO in the Re-Invite message.
STOP sending UPDATE message and keep forwarding the call by RE-INVITE MESSAGE.
Traces Attached for your references.
I'm sure that I see the employee number in my debugs!
Attached are the screenshots and some files from my ITSP please take a look at it also.
Thanks and I really appreciate your response.
I have not looked at debugs yet but when it comes to transfers on CUBE, you get a lot of RE-INVITEs and UPDATES that some ITSP cant process correctly. You can disable all this using midcall consumption on the CUBE.. Add this command to your dial-peer towards your ITSP or configure it in global mode..
voice service voip
sip
midcall-signaling passthru media-change
or dial-peer level:
dial-peer voice xx voip
voice-class sip mid-call signaling passthru media-change
Please rate all useful posts
Ayodeji I'm very thankful for your reply,
I did the "voice-class sip mid-call signaling passthru media-change" on the dial-peer level, we're still facing the same issue.
please note that this issue is not on the transferred calls only, all calls coming to the CUBE --> CUC IVR --> Hunt-List is having this one-way audio issue.
Thanks a lot
Okay please do another test call, and enable the following
1. debug ccsip message
2. Enable packet capture on the cube as follows.
config t
ip traffic-export profile TAC mode capture
bidirectional
exit
int GigaBitEthernet X/X
ip traffic-export apply TAC size 10000000
end
traffic-export interface GigaBitEthernet X/X stop
traffic-export interface GigaBitEthernet X/X clear
traffic-export interface GigaBitEthernet X/X start
<-MAKE CALL->
++ stop the capture after issue has been reproduced ++
++ collect capture and send to tftp server ++
traffic-export interface GigaBitEthernet X/X copy tftp://IPaddress/Capture.pcap
Attache debug and capture here along with call details
Plus what Ayodeji Okanlawon suggested to do, can you tell us how is the Cube reaching your voice vlan?
I see only one route in the config, and it is for reaching your ITSP. This is assuming the Cube is in flow-through mode.
Thanks for your reply :)
currently we don't have a voice VLAN (data and voice are on the same VLAN 172.25.227.0/24, I know it's wrong)
Thanks for the reply,
I'm trying to regenerate the issue, running a debug is preventing the issue to happen, I kept the debug running and I'll upload the file once I face the issue again.
Thanks again
incoming uri via 1
voice-class codec 1
no vad
no vad
incoming uri via 2
voice-class codec 1
no vad
voice-class codec 1
no vad
Response Signature
Thanks I really appreciate your reply, it was very helpful, I did change our dial-peers to match yours.
Regarding the "What kind of router do you use?" our router is C2900-UNIVERSALK9-M (IOS: 15.0(1r)M16)
And this is the "sh voip rtp connections", what should I do after getting the RTP Port Range from my ITSP? I already asked about it from ITSP.
VGW01#sh voip rtp connections
Max Ports Available: 8091, Ports Reserved: 101, Ports in Use: 2
Global Media Pool 16384 32766 8091 101 2
1 65207 65208 18856 10686 10.170.16.70 10.141.40.233 NO
2 65208 65207 18858 16414 172.25.227.126 172.25.227.30 NO
Found 2 active RTP connections
Thanks a lot
Once you know what range of ports your ITSP uses for RTP you set it with this command.
voice service voip
 rtp-port range range
The default for ISR2, aka 29xx and 39xx, is
16384 32766
Response Signature
Thanks, I'll check and reply to you.
    Hey, after editing my dial-peers everything is working fine now, no one-way audio, we was keeping an eye on it for the last couple of days.
    I would like to thank you very much for your support. And I really appreciate your time :)
Thanks a ton
