09-30-2021 08:54 AM
Hoping someone can help here?
I can import a record to a dialer campaign without issue using Postman- as per below screen shot.
As you can see below - I get a 200 OK and I can confirm the record is in the Outbound Dialer Database.
However when I use the same import data on CVP Call Studio I get a HTTP 400 error back from the AW tomcat web server with the following returned response:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?> <apiErrors> <apiError> <errorMessage>400 Bad Request - javax.xml.bind.UnmarshalException - with linked exception:[org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.] </errorMessage> </apiError> </apiErrors>
Anyone know if I can use the REST API successfully to import a record to the CCE Dialer?
Below is a screen shot of the Rest Element in Call Studio.
Gerry
Solved! Go to Solution.
10-02-2021 09:36 AM - edited 10-02-2021 09:38 AM
Can you plz try with below request without CDATA.
<import> <fileContent> AccountNumber,FirstName,LastName,Phone01 Key-5551006,Bob,Bobster,0123456789 </fileContent> <delimiter>,</delimiter> </import>
09-30-2021 05:56 PM
10-01-2021 12:25 AM
Content Below.
There are no spaces. I also copied and pasted direct from working Postman version to CVP Call Studio.
And I copied into notepad and saved and then copied and pasted in.
So that why I am struggling to see where the issue is....
<import> <fileContent> <![CDATA[AccountNumber,FirstName,LastName,Phone01 Key-5551006,Bob,Bobster,0123456789]]> </fileContent> <delimiter>,</delimiter> </import>
Gerry
10-03-2021 01:56 AM
Ananth,
Yes, that worked! Thank you SOOO much.
Are you able to explain why this works, while including the CDATA does not?
Gerry
