Problems with Finesse gadget
lmartinez1
Beginner
Beginner
Hi, I'm new to developing gadgets, I have a problem that I do not know how to solve. My gadget shows supervisor information and queue statistics. As I had problems showing the statistics, I took an example of one already prepared and integrated it with the one that shows the supervisor's information. But there is a function with the same name in both. I already made several changes and they did not work. I would appreciate help me solve this problem. Here I send the code in conflict.
handleUserLoad = function (userevent) {
         render();
_handleUserLoad = function (user) {
                                   user.getQueues({
                 onCollectionAdd: _onQueuesAdd,
                 onCollectionDelete: _onQueuesDelete,
                                                        onLoad: _onQueuesLoad,
                                                        onError: _onQueuesError
I think you are stuck in some loop because in onTeamLoad, getUsers's onLoad is _onTeamUsersLoad. Then in _onTeamUsersLoad the addHandler 'change',  is _onTeamLoad again.
You need a different function for the change handler to process the user update and update your UI.
Thanx,
Denise
5 Replies 5
dekwan
Hi Ambrosio,
You can combine the two together. Make sure to add the handler functions (_onQueuesAdd, _onQueuesDelete, etc) to your file or else the code won't get executed.
Also, depending on which function you keep, it might be userevent.getQueues or user.getQueues.
Thanx,
Denise
Hi, Denise.
I thank you for taking the time to get me out of my doubt I will put into practice your instruction. Taking advantage of the contact I have another doubt. Develop a dashboard that extracts the supervisor’s data and sow information about the agents of your team, such as state, extension and id. Everything works fine but when there are movements in the state of the agents they are not update in the displayed. Then I send you the code and if you can tell me where the error is, I would appreciate it.
_onTeamUsersLoad = function(users) {
var AgentId = new Array ();
var Status = new Array ();
var Exten = new Array ();
var usersCollection = users.getCollection();
for (var userId in usersCollection) {
var teamMember = usersCollection[userId];
var user = usersCollection[userId];
var userFirstName = user.getFirstName();
var userLastName = user.getLastName();
var agentId = user.getId();
var extension = user.getExtension();
var userTeamName = user.getTeamName();
var userState = user.getState();
var agentID = agentId.slice(0, 6);
AgentId.push(agentID + " | ");
UserState = userState.toLowerCase();
var Userstate = UserState.slice(0, 6);
Status.push(Userstate + " | ");
if (Userstate == "logout"){
var auxiliar = "- - - - -";
extension = auxiliar;
Exten.push(" " + extension + " | ");
usersCollection[userId].addHandler('change', _onTeamLoad);
_onTeamLoad = function (team) {
users = team.getUsers({
onLoad: _onTeamUsersLoad,
onError: _onTeamError
Thank you.
De: Denise Kwan <community@cisco.com>
Enviado el: miércoles, 2 de mayo de 2018 11:59 a. m.
Para: Ambrosio Luis Martinez Rosas <lmartinez@censystems.com.mx>
Asunto: Re: - Problems with Finesse gadget
<https://communities.cisco.com/> Cisco Communities
reply from Denise Kwan <https://communities.cisco.com/people/dekwan> in DevNet > Finesse - View the full discussion <https://communities.cisco.com/message/289360#289360>
Thanx,
Denise
Hi, Denise
Follow your observations in both case and worked correctly. Thank you very much for the help. I will continue to develop things and if I have any doubts I could get upset again.
Greetings.
Enviado el: jueves, 3 de mayo de 2018 11:37 a. m.
reply from Denise Kwan <https://communities.cisco.com/people/dekwan> in DevNet > Finesse - View the full discussion <https://communities.cisco.com/message/289514#289514>
You're welcome. Feel free to ask in this forum if you get stuck.
Thanx,
Denise
Recognize Your Peers
