Q.850, cause 16 SIP call disconnect problem during call incoming and outgoing
mohsin majeed
Level 2
Level 2
Dears,
There is disconnect call issue during the call when an CCX agent make or receives a call.
We opened ticket with ITSP, below is the reply from there side.
    Define PCMA as 1st priority and PCMU as 2nd priority.
·         Able to send early offer in invite message (We are not receiving early offer inside your invite).
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.200.0.7:5079;branch=z9hG4bKech2udosuasfbfccctshoaeba
Call-ID: t4hppccpkpa2dae7tfub7ho7p4fakse4@SoftX3000
From: <sip:505715017@10.100.200.20;user=phone>;tag=obpu2scc-CC-26
To: <sip:1748240430@10.100.100.20;user=phone>;tag=sbc0803679CAA4C-720
CSeq: 5 INVITE
Date: Sun, 03 May 2015 08:42:15 GMT
Allow: INVITE,OPTIONS,BYE,CANCEL,ACK,PRACK,UPDATE,REFER,SUBSCRIBE,NOTIFY,INFO,REGISTER
Allow-Events: telephone-event
Contact: <sip:1748240430@10.226.190.224:5060>
Supported: replaces,sdp-anat,timer
Server: Cisco-SIPGateway/IOS-15.2.4.M4
Remote-Party-ID: <sip:7731@172.29.46.134>;party=called;screen=no;privacy=off
Content-Length: 229
Content-Type: application/sdp
v=0
o=- 7989 7928 IN IP4 10.201.20.45
s=SBC call
c=IN IP4 10.201.20.45
t=0 0
m=audio 48704 RTP/AVP 0 97
a=sendonly
a=rtpmap:0 PCMU/8000
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
a=ptime:20
INVITE sip:505715017@10.200.0.7:5079;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.226.190.224:5060;branch=z9hG4bK5EC4654FCT23398
From: <sip:1748240430@10.100.100.20;user=phone>;tag=sbc0803679CAA4C-720
To: <sip:505715017@10.100.200.20;user=phone>;tag=obpu2scc-CC-26
CSeq: 103 INVITE
Date: Sun, 03 May 2015 08:42:18 GMT
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M4
Max-Forwards: 70
Expires: 180
Cisco-Guid: 0158519454-4037480932-2200222861-0419911670
Content-Length: 0
How i can configure these two parameter "early offer" and "PCMA,PCMU"
Your help
9 Replies 9
Murali_DS
u can enforce early offer in Dial peers. Refer the below.
http://www.cisco.com/c/en/us/td/docs/ios/voice/cube/configuration/guide/vb_8241.pdf
Hope this helps.
Thx,
M
Chris Deren
Create codec class on the GW with ordered G711alaw and G711ulaw and then apply this class to your dial peers.
Thanks for your reply,
I also tried as you suggested but no benefit. Now, i configured only one G711alaw.
I attached logs from RTMT may can help to trace the issue.
In debugs the calling number from mobile is 508261660 and called number 8001256666
I will upload the Gateway logs later
Mukesh Kumar
Level 3
Level 3
Hi mohsin,
Did your issue resolved by configuring early offer?
Or have you done anything else to resolve it?
I am facing the same issue. Call disconnected when the other end pick up the call. In the debugs it shows the same reason cause 16.
MUKESH KUMAR | Network Engineer
Spooster IT Services
Computer Networking Solutions
Hey Mukesh Kumar,
FYI... Q.850 Cause Code 16 defines normal clearing. Call disconnection usually refers to Codec mismatch problem. Please cross check what Codec your ISP is sending you G711Alaw or PCMA, G711ULaw or PCMU, G729, etc...
Post this, follow Chris Deren comment.
regards,
Ritesh Desai
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
Thanks for the information Ritesh.
Codecs are same on both end.
On our end we are using SIP delay offer and on the SIP provider end they are using SIP early offer.
Is this can be the issue of call disconnecting?
can you please do ccsip message debug for the problematic call on Voice gateway and post the logs here?
At Mukesh Kumar,
Sharing of debug ccsip messages and details of Infra would help to solve the issue.
regards,
Ritesh Desai
Dear Mukesh,
We opened this case with cisco even. They also replied that this is "normal call clearing". But, believe me this was not normal clearing even there is a message. We (with cisco) couldn't resolve the issue. We tried many things like playing with the codecs and early offer. Our company didn't wait too much because their business based on it. So, finally we had hosted our call center.
But follow the suggestions from community experts; may you have success.
