03-29-2012 04:41 PM - edited 03-14-2019 09:37 AM
Does anyone if you can do silent monitor on cisco IP communicator?
Thanks.
03-29-2012 06:18 PM
Hi Horaciao,
IP communicator version 7 with Call manager 6.1.3 or higher can be used for silent Monitoring.
http://www.cisco.com/en/US/docs/voice_ip_comm/cipc/7_0/english/release/notes/CIPC70_RN.html#wp99775
*Service Observing (Recording and Monitoring)
Hope it helps,
Anand
Please rate helpful posts, by clicking on the stars below the right answer!!
03-30-2012 01:08 AM
Horacio,
what UCCE/UCCX version are you using?
It's possible to do SPAN-based silent monitor on lower versions as well (even though there might be some issues with it).
G.
03-30-2012 06:16 AM
As I recall, there was a problem with monitoring/recording these if you had 'friendly' names (e.g. SEPHORACIO instead of SEP012301230123 style). If you didn't name them MAC-address style the SPAN services didn't like them.
Not sure how current that is...
Aaron
03-30-2012 03:52 PM
Hi All,
As Aaron stated Communicator profile name should be the MAC address of the phone.
Also make sure that in the IPcommunicator preferences ( right click on IPcommunicator -
preferences) - "use Network adapter to generate device name" - network adapter - select the monitoring NIC.
The device name will be the MAC address of Communicator.
Else monitoring will fail with the following error
DEBUG [0xd84] CFCDMSnifferSession.cpp[407]CFCDMSnifferSession::setFilter: End. Invalid MAC address. Returning
false
Thank you
Anuj
10-21-2012 05:58 AM
Can anyone please help. I can do silent monitoring from a softphone to a hardphone. However, when I attempt to do slient monitoring from one softphone to another softphone I keep getting the error ensure Built-Bridge is On and it has capacity for monitoring. This has be check but error is the same (Error code 131414). Can anyone help please
10-21-2012 08:23 PM
Hi Olanrewaju Olarotimi,
Please check the below link,
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/UC6.0.1/features_apps/CMmonrec.html
Anand
Please rate helpful posts !!
