11-15-2011 06:39 AM - edited 03-14-2019 08:53 AM
Is it possible to dial into an application via a phone and silent monitor an agent? Example, training class with a conference phone turned on and listening to an agent for an hour.
11-15-2011 06:50 AM
I am not aware of any application included with UCCE.
However, it's relatively easy to build such an application, since CTI OS supports - or, at least, exposes - API calls to start silent monitoring from a third party application. It's even easier with Gen3 phones since they support CUCM-based silent monitoring using their built in bridge (BiB).
G.
11-27-2011 06:51 AM
Is there a sample code snippet that outlines which Cisco APIs and subsequent API calls are needed to instantiate a silent monitor?
11-27-2011 06:56 AM
Is there an RSM (Remote Silent Monitoring) product from Cisco?
Geoff
11-29-2011 06:09 AM
I'm particularly interested in the socket based protocol that is available in UCCX.
11-29-2011 08:00 PM
hmm what about the remote monitoring for UCCX....there you need to create an application and use the rmon.aef system script? Maybe that can work for you
Gabriel.
09-08-2014 05:18 AM
Checkout the doc if it helps.
https://supportforums.cisco.com/document/12296686/silent-monitoring-cisco-call-manager-without-need-uccx
You can do silent monitoring using a application service configured in the Cisco IP Phone
