10-03-2017 09:47 AM - edited 03-15-2019 06:33 AM
UCCE 11.5 Compatibility - ICM script coded in 11.5 will work in ICM 9.0 ?
Is the script reverse / backward compatible.
I got the errro - parsing of the current import file failed. Aborting import when icm 11.5 script imported to ucce 9.0.
Is it because of Jave version difference as the tomcat /jre version changes...
10-03-2017 09:52 AM
Never did such thing, but the script should work for the nodes which were there or not introduced after 9.0. when you export and import a script into the ICM and if there is any error, this script editor is going to show you and ask you to map the those unreferenced objects. so best to try it by your self.
10-03-2017 11:03 AM
Thanks for prompt response.
It seems like reverse compatible not supported.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy20349/?referring_site=bugquickviewredir
10-03-2017 10:53 AM
Does your script utilize any nodes (like some of the dynamic ones) that are not present in version 9?
10-03-2017 12:13 PM
No dynamic menus it plain vanilla call flow, assuming network VRU script microapp nodes giving the errors.
