1000V port channel to N5K w/ FCOE
jpazahanick
Level 4
Level 4
Is it possible to port channel 2 10G ports on the Nexus 1000V (Emulex CNAs) with 2 10G ports on the Nexus 5000 if the ports on the Nexus 5000 ports are also doing FCOE?
I am getting the following error:
N5k(config-if-range)# int  e1/5-6
N5k(config-if-range)# channel-group 10 mode on
command failed: port not compatible [port mode]
Previously I was getting an error along the lines of "Port already assigned to virtual interface (VIF).
The configuration of the 5k is attached.
46 Replies 46
Robert,
     I have tested with a static port channel (as you can see in the configurations in one of my previous posts and the behaviour was the same ...
     I have tried to create the port channel with all the possible scenarios and allways got the same behaviour ...
Nuno Ferreira
Sorry Nuno, getting mixed up with too many things on the go.
QLogic is aware of the issue and have been able to reproduce it in house.  I'm waiting to hear back further from their development team on the issues with static PCs and their adapters with Windows driver.   I will update this thread as new information is passed.
Robert
Thanks Robert ....
Please be aware that I have tried both Port Channel config (mode active and mode on)
Thanks again ... will standby for your update
Nuno Ferreira
Hi Robert,
     Sorry for chasing but do you have any update from Qlogic ? (Or even from yourselves @Cisco) ?
     Did you see the note about me trying different modes on the port channel and all with the same behaviour ?
Nuno Ferreira
Just got an update today actually!
Qlogic just tested this scenario with their latest windows drivers and it still failed with static port channels.  They have their DVT team recreating & debugging this as we speak.
Tracking under QL Support Case 70037950
Cisco Bug ID: CSCtg56093
I'll continue to update this thread if anything changes.
Robert
Lovely Rob
Thanks for the update .. I will keep with my eyes on this thread for your updates
Thanks again for your help
Nuno Ferreira
Rob,
Just tuning into this thread.  Seeing the same issue with 8152 on Win2K3 and static 802.3ad (channel-group mode ON) in VPC mode on dual 5020 running NXOS 4.2.  What is the status from Cisco and Qlogic?
Guys - I've just heard back from Qlogic on this - unfortunately not great news.  Here's the update:
2010-06-09  15:12:11 PDT
[Notes]
Robert
I'm working on getting a clarification on the timeline. So far I  have a rough timeline of August. I'm trying to get our marketing to  nail that down. I had just pinged the right guy today but he has not  provided a response yet.
[Notes]
Robert,
At this time the teaming driver to not support being  attached to a port channel on the switch.   I am waiting for a formal  response from the BU with better wording and an ETA on when that support  will be added to the windows teaming drivers. It's in the works though.
I'll keep this thread updated if I hear anything further.  I'll follow up with QL next month.
Robert
Rob,
     Thanks for the update. So the Teaming does not work AT ALL ? Or, for example, if we just put the 2 connections in a vPC it will work ? (ie. just do the vPC and not the HW Port-Channel ?)
Nuno Ferreira
No teaming at all.  You can't do an upstream vPC on the N5K without teaming on the host.  Your only option for now is to use an individual link with Windows at this point unfortunately.
Robert
Sorry I'm jumping on this late.  If I'm understanding the issue correctly, you want to vPC from your ESX server to a pair of N5K with FCoE as well.  I understand the issue with Qlogic and we are working with them to get this resolved.  But what we are suggesting to customers who are doing FCoE and want to do load-balancing between the 2 10G links is on the N1K uplink port-profile, set the channel-group auto mode on mac-pinning.  This will be equivalent to what VMware vswitch does to do with source virtual interface pinning as well.  Please let us know if that helps or if I miss the question entirely.  Thanks,
Cuong
Cuong,
This thread started as an ESX w/ QL -> N5K issue, which we're waiting on QL to publish the fixed drivers for.
The recent postings are in regards to Windows (bare metal) and QL's inability to do teaming on the host with the current driver release.  I'm tracking this issue with QL.  Ping me offline if you want the details.
Robert
This is not about ESX and QLogic but Windows and QLogic. The ESX Drivers appear to work ... the Windows don't
Cheers
Nuno Ferreira
Update!
Qlogic has expedited the completion of their latest driver update for Windows.  I'll be running through some testing with the new driver this week and hopefully the driver will be publicly available from their website in the next week or two.
Stay tuned for testing results to be posted mid this week.
Robert
Rob ... that's great news ... Thanks for keeping up with this and will stay tuned for updates
Nuno Ferreira
