09-26-2011 12:57 PM - edited 03-16-2019 07:11 AM
can anyone recommend a 3rd party software that interfaces with Call Mgr CDR's? This would be for CUCM 8.x
Nothing extensive in the way of reporting will be needed. I just need something nice and clean that will decipher CDR's.
Thanks.
09-26-2011 01:29 PM
05-29-2019 11:38 AM
Jonathan, thanks for the scoop. All the best, man.
09-27-2011 01:32 AM
Would something like this work?
Where you can even create customized reports based on the Dept field from UCM:
And have them automated and emailed on a scheduled basis:
05-17-2016 11:23 AM
toothfairy - What product is your screenshot from?
10-02-2011 12:38 PM
you can also try our ptoduct - http://2ring.com/tas. It is good for nearly any VoIP environment set up.
Or just ask me more question about it, I'll answer.
Jiri
10-02-2011 10:51 PM
Nevotek - Sigma5 & CTIGroup - Proteus are good products
http://www.nevotek.com/p_sigma5.html
http://www.ctigroup.com/solutions/call-accounting-and-reporting/
10-03-2011 01:34 AM
There are many call accounting and call logging products listed on the Cisco developer website http://developer.cisco.com/web/partner/search?text=call+logging&technologyIds=&subTechnologyIds=&technologyProductIds=&technologyProductVersionIds=&partnerProductFamilies=&verticalIndustryCategoryId=&availableVerticalIndustryCategories=&_regions=on&_...
Our TIM Plus and TIM Enterprise have AXL integration to sync with your UCM so that it auto configures itself. Display boards are included free of charge.
Both are Cisco IVT tested so you can be sure that it is compatible. For a video of the product in action or to arrange a free trial go to our Cisco microsite www.tri-line.com/cisco
03-04-2019 09:49 AM
04-16-2019 04:44 PM - edited 04-17-2019 05:49 AM
I would like to submit Call Record Analyzer (CRA) to this post. CRA is 100% cloud based and was written solely for Cisco UCM. CRA provides troubleshooting, analysis, and department level reporting for tech and non tech staff. 100% risk free trial and it only takes about 15 minutes to have up and running. https://www.callrecordanalyzer.com
Why are we different? We are an agile software company lead by Mike Cotrone Cisco CCIE #8411 Voice Route/Switch and Robert Misior CCIE #41385 Voice.
10-03-2019 11:52 AM
Bit of an old topic, however I see that it's still being referenced around the forum.
I'm the author of VoIP Detective, a call reporting tool for Cisco Callmanager. There is a free version (that has no time limit), as well as a paid version. It's made to be easy to use for both administrators, as well as end users. No client to install, and it's deployed on premise as a VMware image.
VoIP Detective - CDR reporting
