3rd party solution to customize CUCM (v7.x -8.x) CDR
xiaoliangyue
I've heard there are such solutions in market, any suggestions? my client doesn't like to read the CDR that CUCM generates, they want a customized, friendly looking one.
thanks.
4 Accepted Solutions
William Bell
Yes, there are quite a few. This is one of those applications where you will want to check out a few vendors and try things out. ISI is a company that I usually consider if a customer doesn't have an incumbent product or the incumbent product doesn't support CUCM. They aren't the only one or the best, I have just used them before and they have been providing call accounting solutions for Cisco products for quite some time.
ISI:  http://www.isi-info.com/solutions/CiscoCallAccounting.htm
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Gordon Ross
Level 9
Level 9
You want a call logger. This takes the CDR feed and turns it into, well, whatever you want.
http://www.tigercomms.com/ produce one that understands CUCM very well.
One of the things you need to be aware of, is that different products "understand" CUCM to different levels. Some will just say "A called B". Others (e.g. Tiger) will pull out every last detail from the CUCM data feed.
Call loggers aren't just about billing - they're one of the many tools you need for trouble-shooting.
GTG
Please rate all helpful posts.
7 Replies 7
William Bell
HTH.
Bill
Gordon Ross
Level 9
Level 9
GTG
And I'll add one more
http://www.oak.co.uk/call-logging
HTH. Barry
thanks guys, really appreicate your help!
the local Cisco SE just taught me a way, go to http://developer.cisco.com/web/partner/search, search CDR.
eduardo_ojeda
Hi everybody,
Is it possible using Crystal Reports??
Thanks.
Eduardo
eduardo.ojeda@unifiednetworks.com.mx
JiriPrinc
you chould consider also any call accounting system for that. Some listed above, and here is one more: www.2ring.com/tas
Edit: more of these can be found here -
http://developer.cisco.com/web/partner/search;jsessionid=D0912B67F4FBE9030194425B9779E123.liferay-portal1?text=call+accounting&technologyIds=a0G40000000xlnlEAA&availableTechnologies=a0G40000000xlnlEAA&subTechnologyIds=&technologyProductIds=&technolog...
Jiri
Message was edited by: Jiri Princ
