7915-12 not working for CME
belemgarrido
I am configuring a 7915 module for a 7962G ip telephone on a CME. I'd configured the ephone and upload its firmware but the module shows at the screen the Cisco logo and all of the buttons are steady amber, all of them.
Is there any configuration that I'm missing or this expansion module is defective?
Thanks for your help.
tftp-server flash:B015-1-0-2.SBN
telephony-service
load 7914 S00105000300
load 7915-12 B015-1-0-2
load 7911 SCCP11.8-4-2S
load 7921 CP7921G-1.1.1
load 7937 apps37sccp.1-2-1-0
load 7960-7940 P00308000500
load 7945 SCCP45.8-4-2S
ephone  85
device-security-mode none
description Call Center
mac-address ECC8.8211.BC6E
after-hours exempt
blf-speed-dial 1 350 label "Normita"
blf-speed-dial 2 351 label "Dr.Ruiz"
blf-speed-dial 3 228 label "Resultados"
blf-speed-dial 4 352 label "SalaJuntas"
paging-dn 234
type 7962 addon 1 7915-12
button  1:106 2:6 3:7 4:8
button  5:70 6:71
7 Replies 7
Ayodeji Okanlawon
Belem,
Can you run this debug
debug tftp events
Then unplug the phone and plug it in again..Please put the output in a text file and attach here..
Also send the output of
show telephony-service tftp-bindings
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts
Hi aokanlawon,
I ran the debug you asked me and there are no results, it seems that the expansion module is not asking for its firmware and same thing for the telephony-service tftp-bindings, I couldn't get the output of the tftp-bindings because the user is in a remote office.
Any ideas about what's happening?
Thank you very much.
m.junghage
Balem: Make sure that the phoneload for the sidecar is compatible with the phoneload for the phone it's attached to. To be sure, upload the latest phoneloads for both the phone and the sidecar.
Best regards
Markus
Hi m.junghage,
I already have the latest version of the phone and the expansion module.
Any ideas??
Thanks!!
Regards.
Did you resolve this? Same issue here.
Thanks!
The problem was on the telephone firmware, the expansion module was on a 7962 which needs its firmware named SCCP42.8-5-2S. In the configuration above I had only the 7960-7940 firmware loaded that's why the expansion module couldn't register.
Hope it works.
Regards.
A long time since the question was posted but one thing struck me when rereading it. Have you verified that the phone can reach the tftp server at all? If you don't see tftp request in the debug one should suspect that it can't communicate with the tftp server.
