7942/7962 PHONES SHOWING DIFFERENT TIME
nithin louis
I am having an IP telephony set up with CME with Version 4.2(0).The phones are taking the time from the PBX itself.we are having 7942 and 7962 IP Phone models.
The isue is that some of the 7942 and 7962 are showing in correct time and some of them showing correct time.
I checked the Firmware for both (correct and incorect) but are same.I have  reset the phones couple of times ..but result is same....
please review the below Sh Telephony service ....
Please help for the same.
Thanks in advance....
Nithin Louis.
AWRIS#   sh telephony-service
CONFIG (Version=4.2(0))
Version 4.2(0)
Cisco Unified Communications Manager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 192.168.0.2 port 2000
service dnis overlay
service dnis dir-lookup
load 7902 CP7902080002SCCP060817A
load 7921 CP7921G-1.0.4
load 7936 cmterm_7936.3-3-13-0
load 7970 SCCP70.8-2-2SR2S
load 7971 SCCP70.8-2-2SR2S
load 7962 SCCP42.8-3-2S
load 7942 SCCP42.8-3-2S
load 7945 SCCP45.8-3-2S
load 7965 SCCP45.8-3-2S
load 7975 SCCP75.8-3-2S
load 7961 SCCP41.8-2-2SR2S
load 7961GE SCCP41.8-2-2SR2S
load 7941 SCCP41.8-2-2SR2S
load 7941GE SCCP41.8-2-2SR2S
load 7931 SCCP31.8-2-2SR2S
load 7911 SCCP11.8-2-2SR2S
load 7906 SCCP11.8-2-2SR2S
load 7914 S00105000200
load 7960-7940 P00308000500
load 521G-524G cp524g-08-01-07
max-ephones 40
max-dn 100
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 5
dialplan-pattern 1 17568... extension-length 3 extension-pattern ...
dialplan-pattern 2 17533... extension-length 3 extension-pattern ...
voicemail 7777
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US   (This is the default network locale for this box)
--More--                           network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line mode is single
phone service videoCapability 1
moh music-on-hold.au
time-format 12
date-format dd-mm-yy
timezone 31 Saudi Arabia Standard Time
secondary-dialtone 9
url directories http://192.168.0.2/localdirectory
url services http://192.168.0.4/voiceview/common/login.do
url authentication http://192.168.0.2/CCMCIP/authenticate.asp
call-forward pattern .T
call-forward system redirecting-expanded
transfer-pattern 9.T
transfer-pattern .T
after-hours block pattern 1 900.T
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
keepalive 30 auxiliary 30
timeout interdigit 5
timeout busy 10
timeout ringing 180
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message **********AWRIS**********
web admin system name cisco  secret 5 $1$J8mU$BVFvb6Xf.7WO1smFuQ.wI1
web admin customer name Customer
edit DN through Web:  enabled.
--More--                           edit TIME through web:  enabled.
Log (table parameters):
     max-size: 150
     retain-timer: 15
create cnf-files version-stamp 7960 Apr 21 2012 06:26:05
transfer-system full-consult
login timeout 5
multicast moh 239.10.16.16 port 2000
auto assign 10 to 43
auto assign 5 to 8 type ANL
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Call List BLF is enabled
Nithin,
Try
config t
telephony-service
no create cnf-files
create cnf-files
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
8 Replies 8
Makesure that NTP server is configured and synched using "show ntp status" command. Also, makesure that proper time zones are configured.
hi mohamed,
i configured ntp..but still no luck......
Nithin,
Try
config t
telephony-service
no create cnf-files
create cnf-files
Alex.
HI Alex,
I tried ...but still no luck...
paolo bevilacqua
Check that you have 'type' correctly configured for all the ephones.
Thai Huynh
You have to reload IP phone firmware with the same firmware version on all phones (reload phone firmware with your CME router). Hope that help
According to the OP, it's the same firmware already.
Hi Alex,
I tried with your configuration ......Then I reset all the phones from the Telephony-services.....Then it takes the correct time.
Thanks you all for your kind support.
