I'm not quite sure when it happened, if it was after an upgrade or a recent reset of all phones but we've had several complaints from our end users that if they are on headset during a call and then when they end the call, the headset light doesn't go off. But the call is definitely ended. Is this by design or do we have a bug?
IP phone 7942G
CUCM version 10.5.2.14901-1
Solved! Go to Solution.
Hi there,
I wanted to add a note to the good info from my friends Manish & Mohammed (+5 each!). I think you may be running into a Bug/Enhancement related to the firmware that was implemented during the upgrade. Can you let us know if this is the firmware running on the 7942's.
Symptom: Firmware: 9-4-2SR1-1 With most of 79XX Phones we can see the headset lit stays with green even after disconnection of the call (in idle state)
Cheers!
Rob
Hi there,
When looking at the write up for this bug it looks like any newer 10.x or 11.x firmware should address this issue.
Cheers!
Rob
This appears to be working as designed
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/9971_9951_8961/10_0/english/userguide/P567_BK_UB293500_00_userguide-8961-9951-9971-10_0/P567_BK_UB293500_00_userguide-8961-9951-9971-10_0_chapter_010.html#CUIP_TK_AC0F90A2_00
If your phone is set up to answer calls automatically, you don't do anything when your phone rings. After one ring, you're automatically connected to the call using the speakerphone.
If you prefer to use your headset to answer the call, set up your headset first.
If you automatically answer calls on your speakerphone and you change the call to the headset, your next incoming call automatically answers on the headset. If you automatically answer calls on your headset and you change the call to the speakerphone, your next incoming call automatically rings on the speakerphone. Automatic answer ensures that the call is answered; it does not change the location you used for the previous call.
Can you make sure that hookswitch option is disabled in your phone.
Hi there,
Cheers!
Rob
Ah! That's the exact firmware version I'm running! Thanks Rob! And thank you Manish and Mohammed for replying as well. To answer your question about hookswtich, that option is disabled but this is happening with wired headsets.
Getting back to the bug, are they stating that this is an enhancement so there's no "fix" for it?
Hi there,
Cheers!
Rob
Thanks again Rob!
You are most welcome my friend!
I found this bug in SCCP42.9-4-2SR3-1S also, and resolved it by rolling back my 7962 phones to SCCP42.9-3-1SR4-1S.
Refer to this guide for installing a single phone firmware: https://community.cisco.com/t5/collaboration-voice-and-video/upgrade-downgrade-firmware-of-specific-ip-phone/ta-p/3137526/show-comments/true
You can download the phone firmware from the cisco software center.
