Add Ip address on CUCM SAN certificate
nicanor00
I have CUCM 12.5 and my CA
For internal purpose, I need to add IP address as SAN on the certificat
How can I do it ?
12 Replies 12
You can add the IP address in CN field.
output of csr decoder(online tools) to see the csr details
On CUCM while generating csr I added common name As ip address
Response Signature
nicanor00
Hi and thanks for your answer
It look like we dont have the same interface, anyway we have the same menu
I need to generate CSR for  : tomcat, call manager and IPsec
I have CUCM and IM&P (suscriber and publicher on each)
the CUCM name is ABCD.tomato.com
the domain name is tomato.com
The ip adress of the CUCM is 192.168.0.1
My CA accept only one unique common name, so  it can not accept 2 CSR with the same common name
When I put ip adress of the CUCM in the SAN, it doenst accept
I my situation, Please how Can I add ip adress in the SAN ?
We both have same interface. Add the IP in common name and add FQDN on SAN
Response Signature
Great answer by Nithin above. Just remember that you can add more than one SAN separated by a comma. So if your Signing Authority returns the Certificate with the top level domain or www on the front(GoDaddy), you can add more SAN's in that field.
Please rate if this helps.
Hi all
Thanks for your answer
I need to generate 3 CSR  : tomcat, ipsec and call manager
My CA cannot accept 2 CSR with the same common name (same cucm ip adress) for all those 3 CSR
So please how can I manage it ?
I never seen such an issue  that My CA cannot accept 2 CSR with the same common name. I have renewed CSR for all the  services you mentioned, and my server team was able to sign it using Microsoft CA for all individual CSR.
Response Signature
Vinod16
@Nithin Eluvathingal  Hi nithin,
I am adding IP in CN and IN SAN - parent domain  ( domain , FQDN cucm) but getting error while generating Cert.
Invalid Parent Domain. Please use a standard domain format.
CUCM 12.5
You cannot enter an IP address in the field parent domain as a SAN entry. As already written by @Nithin Eluvathingal
You cant add the IP on the parent domain.
Response Signature
Like I'm also having the same problem. I also tried to create a CSR with Distribution as "Multi-server" but don't know how to add IP addresses to the SAN field. Can you share with me how to do it properly, please?
If you would read carefully, then your question would be unnecessary:
"You cannot enter an IP address in the field parent domain as a SAN entry."
As @b.winter and @Nithin Eluvathingal already have written you cannot add IP addresses to the CSR. It is not intended to work as it is not a proper thing to do in a certificate. It should only contain FQDNs and DNS domains.
Response Signature
