05-04-2016 07:31 AM - edited 03-17-2019 06:49 AM
Hi all,
Any advice that how I can add prefix ( such as 9) to Received/Missed Calls directories on phones?
So people could just call back by searching the received/missed calls directories and then click dial.
Looks there are two options ... one is to make changes on CUCM , the other is on voice gateway. I would like to know about more details.
Your information is appreciated.
Master001
Solved! Go to Solution.
05-04-2016 08:39 AM
Apart from great suggestions below by my friends,which applies to incoming direction on gateway.
Another way is in outbound direction where you can match a translation pattern as soon as someone presses the missed the call number and then add prefix 9 before sending it out to the route pattern.
05-04-2016 07:39 AM
Hello Master,
Here is the nice doc explain about prefixing
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/68223-digit2.html
br,
Nadeem
06-28-2016 12:52 PM
thanks Deepak and Nadeem for the support. I added prefix on IOS gateway using translation rule etc. and it works perfectly.
Master001
05-04-2016 07:40 AM
https://supportforums.cisco.com/discussion/12679101/cucm-100-how-translate-or-transform-add-prefix-incoming-call-pstn
Deepak
05-04-2016 08:39 AM
